Electrostatic physics?
[SOLVED] electrostatic physics?
a cabin contains only two small electrical appliances: a radio that requires 10 milliamperes of current at 9 volts and a clock that requires 20 milliamperes at 15 volts, a 15 volt battery with negligible internal resistance supples the electrical energy to operate the radio and the clock
Calculate the resistance and calculate the electrical energy that must be supplied by the battery to operate the circuits for 1 minute
R= I/V and energy= (power)(t) and power = V x I
I know that the second appliance needs 9V, so you need to drop 6V across the resistor (15-9).
does that mean i plug in 9 for V to find R? then I equals 10 milliamperes which i multiply by 10^-3 to convert to amperes
and i totally don't get the second part
Answers and Replies
msg me for a picture if you think it will help you
thank you!!
rock.freak667
6,223
31
The resistance of what exactly are you to calculate?
A picture would help ;).
I cannot visualize circuit diagram from the question.
rock freak: the directions only say calculate resistance, no additional details
rock.freak667
6,223
31
Post the picture
Redbelly98
Staff Emeritus
Insights Author
12,134
161
R= I/V
You'd better double-check that equation.
No, plug in the voltage across the resistor R.
Yes.
As a start, can you calculate the power supplied by the battery?
Redbelly98
Staff Emeritus
Insights Author
12,134
161
A resistor and a radio are connected in series.
The resistor+radio is connected in parallel with a clock.
Then, all of that is connected to the battery.
rock.freak667
6,223
31
ah that makes sense now....
my bad, it's V/I
so 15 instead of 9?
uh i really don't get how they're connected
rock freak i can't post the pic, it says im not allowed
rock.freak667
6,223
31
my bad, it's V/I
so 15 instead of 9?
The radio and resistor are in parallel with the clock. since they are in parallel they have the same pd.
so the pd across the resistor+pd across radio=15
radio uses 9 => resistor has a pd of=15-9=6V
and you know that R=V/I, can you find R now?
what is pd?
is I 20 milliamperes?
so i multiply 20 by 10^-3
i get .02
so then i did 6/.02 and got 300 ohms
Redbelly98
Staff Emeritus
Insights Author
12,134
161
my bad, it's V/I
so 15 instead of 9?
No, the number you said before:
NavitaLaVida said:
... you need to drop 6V across the resistor (15-9)
NavitaLaVida said:
what is pd?
Potential difference. It means the same thing as voltage.
For the resistor that is in series with a 10mA radio, to find ohms, should we use 6v/.01 or 6v/.02? My teacher gave me a whole worksheet of similar problems where you need to add a missing resistor. I don't understand whether or not we should have 20mA on the bottom. Would you use 10mA on the bottom because it needs to add to the 10mA radio?
Related Threads on Electrostatic physics?
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
