Electrostatic Potential
  • Thread starter Alex_Neof
What is the electrostatic potential for the electric field in the region x ≥ 0 where:
E
= (E0)*e^(kxi) V/m, with E0 a constant?
(The potential at x → infinity is defined to be zero).
b
v = v_a - v_b = - ∫ E . dl
a
v = - ∫ (E0)*e^(kx) dx = (E0)/k.
infinity
Is this correct?
Kind regards.
Answers and Replies
BvU
15,030
4,081
Helo Alex,
You can check for yourself if this is correct: how do you derive an electric field from a potential ? Does that work OK for your answer ?
Oh, and did I miss a minus sign somewhere ?
Thank you BvU !
BvU
15,030
4,081
Does that mean you found a potential ##E_o\over k## V gives an electric field ## \vec E = E_0 \; e^{kx} \; {\bf \hat\imath} \ ## V/m ?
BvU
15,030
4,081
So I was given the electric field:
##\overrightarrow{E} = {E_0} e^{-kx}\hat i. ##
Which is completely in the x-direction.
Now using:
## V = {V_a} - {V_b} = - \int_a^b \overrightarrow{E}.\overrightarrow{dl}, ##
with the above electric field we have:
## V = - \int_\infty^x {E_0} e^{-kx}dx = \frac{E_0} {k} e^{-kx}.##
Then using what BvU suggested:
Helo Alex,
I remembered from my notes that the electric field is related to the potential as follows:
##\overrightarrow{E} = - \nabla V.##
So to test if the potential I found is correct, I just plug it in and find:
##- (\frac{\partial V} {\partial x})=-(-{E_0} e^{-kx}\hat i) ##
Which gives us back our original Electric Field:
##\overrightarrow{E} = {E_0} e^{-kx}\hat i.##
Thanks again BvU, much appreciated!
BvU
15,030
4,081
well done !
Initially my limits for integration were wrong, I had them from ##\infty## to 0.
Related Threads on Electrostatic Potential
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
10K
