saubhik
- 31
I am stuck with some misconceptions about electrostatic potential/ potential difference. Please read what follows and correct me wherever I am wrong. Help appreciated. Thanks.
Consider a dipole-like charge configuration (fixed at their positions by unspecified forces ) with the separation between the two equal and opposite point charges [tex]2a[/tex]. Clearly, there is a point between the charges where the electrostatic potential due to configuration is zero, assuming that the electrostatic potential due to the charge configuration at a point infinitely separated from the configuration is zero. In fact, this point say, [tex]P[/tex] is the mid point of the separation; the point being separated from each charge by [tex]a[/tex].
Now, the work done by external forces in bringing a point charge [tex]q[/tex] to the mentioned point infinitesimally slowly, from infinity, is zero since the electrostatic potential difference between the initial and final position of the charge [tex]q[/tex] is zero. Now, the work done in moving the point charge by conservative electrostatic forces is independent of the path taken which implies that the work done by the external forces being equal and opposite to the conservative electrostatic force is also independent of the path taken by the point charge. [Thus the external force behaves like a conservative force. In general, it can be said any force acting on a particle in a conservative force field, if displaces the particle infinitesimally slowly, is a conservative force.]
Suppose, the external agent brings the point charge [tex]q[/tex] from infinite separation (from the configuration) to the point [tex]P[/tex] through a path that goes through one of the fixed charges constituting the configuration. At the point at which the fixed charge is present, the electrostatic potential is not well defined. Therefore at a point in this specific path the electrostatic potential loses its definition. How can we ,then, say that the work done by the agent through this path is zero? (Assume that the electrostatic potential due to the charge configuration is zero at a point infinitely separated from the charge distribution.)
Suppose, the external agent now brings the point charge [tex]q[/tex] from infinite separation (from the configuration) to the point [tex]P[/tex] through a straight path that goes through the vicinity of one of the fixed charges. (Visualize this path as a straight line making a small angle with the dipole axis, extending infinitely at one direction and terminating at the point [tex]P[/tex]). The electrostatic potential at each point in this path is contributed mostly by the fixed charge in the vicinity, since the distance of any point on this path (obviously, except the final point [tex]P[/tex]) from the fixed charge in the vicinity is lesser than the distance from the other fixed charge. Thus, at each point ,except possibly the final point and initial point, in this path, the work done by the external agent is always non zero and has the same nature (always positive or always negative depending on the polarity of the fixed charge in vicinity of the path). How can the work done by the external force through this path be zero, which is the integration of the work done by external agent at each point of the path?
