Why does a charged Styrofoam plate attract paper but repel aluminum foil?
In summary: So the negatively charged part of the styrofoam attracts the electrons in the molecules of the paper, similar to how positive and negative poles of a battery attract each other.This makes the paper attracted to the styrofoam.In summary, a negatively charged styrofoam plate repels pieces of paper that are nearest to it, moving the free electrons to other parts of the object.
cvc121
61
Based on a lab we did at school, we charged a Styrofoam plate by rubbing it against wool and determined that it attracted pieces of paper but repelled pieces of aluminum foil. Can anyone clarify why this is because I believe that both the pieces of paper and aluminum foil are neutral so wouldn't they both attract?
N/A
My only reasonable explanation is that the aluminum foil is conductive and picks up the electrons from the negatively charged Styrofoam plate and repel while the pieces of paper which act as an insulator attract to the plate. All help is very much appreciated!
N/A
You are on the right track. The charge can not move in the paper pieces, it stays polarized by the Styrofoam, but neutral, while the aluminium foil gets charged as it is in contact with the Styrofoam for a very short time,
Was the foil seen to be first attracted to the plastic plate?
You are very much right cvc.
Intitally they are both attrackted, but upon contact the foil gets charged up and then repelled.
Why would the paper react differently?
Why are they both intially attracted?
Note that sometimes even the paper is repelled after a while. So these conditions or outcomes are not always the same for pieces of paper, but the foil will always act in the way descirbed. Any idea why?
Keep in mind that the styrofoam is also a nonconductive material.
Thanks for the replies everyone! Am I on the right track in saying that the negatively charged Styrofoam plate repels the free electrons on the surface of the neutral pieces of paper that is nearest, moving them to other parts of the object. Hence, this leaves a new positive charge on the side facing the negatively charged Styrofoam plate, and the two unlikes attract.
The paper is not a conductor, it has no free electrons. Its electrons are bound to the molecules, they can not leave their molecules and moving to other parts of the paper.
Ok. So how else are the paper pieces able to attract the negatively charged Styrofoam plate since no movement of electrons take place?
The molecules in the paper are polarized by the electric field generated by the charged styrofoam plate.
1. What is electrostatics?
Electrostatics is the study of the behavior and effects of stationary electric charges.
2. What is an electrostatics lab analysis?
An electrostatics lab analysis is a scientific experiment conducted to observe and measure the behavior and properties of electric charges using various apparatus and techniques.
3. What are the common apparatus used in an electrostatics lab analysis?
Some common apparatus used in an electrostatics lab analysis include Van de Graaff generators, electroscopes, and Faraday cages.
4. What are some applications of electrostatics?
Electrostatics has many practical applications, such as in electrostatic precipitators for air pollution control, inkjet printers, and photocopiers.
5. How does electrostatics relate to other fields of science?
Electrostatics is closely related to other fields of science, such as electromagnetism, which studies the interaction between electric and magnetic fields, and plasma physics, which explores the behavior of charged particles in high-energy environments.
  • Other Physics Topics
20K
13K
10K
