Area of Shaded Region in Elementary Geometry
In summary: But I am highly unsure on the answer I have calculated.So you are looking for a fourth equation?Yes I am looking for a fourth equation.
davon806
148
In the attached diagram,the edge of the square is a. find the area of the shaded region
area of circle = πr^2 ,area of square,triangles
(Please avoid using integration/radian angle/tangent...Since this problem is found in a maths exercise suitable for a 12-year-old..)Thanks
The unshaded corners of the square is easy.The "diagonal leaf" is easy as well.But I have been struggling to find the small portion(marked as A in my diagram) Looking for some insight.Thanks!
Btw,the book mentioned that it might be helpful to draw the same leaf on the left diagonal
You can construct a system of equation with four unknowns and four equations, the unknowns are ##A,B,C,## and ##D##. ##A## is the area of one of the shaded region. ##B## is the portion of the circle inside the diagonal leaf. ##2C## is the remainder of the area inside the diagonal leaf (those two curved triangles at the square's corners). ##D## the small area which you denoted as A. You want to find ##2A##.
Likes davon806
I tried using simulataneous eq. to solve but I couldn't solve the variables I want(i.e. 2A you have mentioned).I ended up with obtaining the same equation after solving some of the variables.
So I look for some alternative method,though I have used trigonometry...But I am highly unsure on the answer I have calculated.I hope someone can comment on those steps,especially MEN~AEF(I simply think they look similar,I don't know whether it is true.)
Thanks
Have you actually solved it that way? I have to say, I'm struggling to find a fourth equation. There are three known areas, the circle, the quadrant and the square, and each yields one equation.
Yes I have done that but I fail to notice that upon elliminating some unknowns, I got two identical equations, like the OP said. I must apologize that my method doesn't work without finding another equation.
Ok, thanks for confirming.
I can find the angles, e.g. the angle the lower left intersection point and the bottom left corner subtend at the bottom right corner. But that's well beyond a 12-year old's standard, and still a long way to go to find the area.
Yeah, the use of some trigonometrics can relieve the problem up to some extent. But I also believe that the use of some identities on a circle can also help solve it.
I think this is an interesting and nontrivial problem. @davon806 I am curious where you got this problem. Using advanced tools unavailable to a 12 year old, I have gotten the area of one of the shaded regions, (taking ##a = 1##, for general a just multiply by ##a^2##):
This expression certainly hides the ##\pi##'s. I was thinking I might be able to reverse engineer from the answer to see what geometry to use. I tell you what -- those ##\sqrt 7##'s don't ring any bells for me. I am curious if anyone has made progress on an "elementary" solution.
I get the same result - at least, when I evaluate my expression and yours they seem to be numerically equal. I got it into the form ##\frac{\sqrt 7}8-\frac 14 \arcsin(\frac{23}{128}\sqrt{14})##, but that's scarcely any nicer.
Thanks
I finally took time to read the images. It is definitely not true that MEN~AEF. The curved boundaries of AEF have equal radii and those of MEN do not. Again @davon806 please tell us where you found this problem.
Likes davon806
My friend sent me a picture and he told me it was found from some sort of exercise suitable for a junior form student in China(about 12-13 years old).I don't know about the Chinese curriculum but I guess if there is an elementary solution,a lot of lines and variables are needed to be drawn on the diagram before we can finally reach the answer.Btw,can you show me your method?I failed to solve it :d Thanks
I used integral calculus to find the answer, definitely not an "elementary geometrical" argument, and not an argument accessible without calculus.
My method was purely geometric and trigonometric, but quite complicated.
The shaded region is called a Lune. I have learned that there is quite a bit of info on the internet about lunes. It turns out there are 5 quadrable lunes (those for which you can construct a square with the same area). I don't know much except what I have recently read about them. I don't think the present example is one of the quadrable lunes, but I don't know whether that has any bearing on whether there is a purely geometric/pythagorean theorem solution or not. I'm thinking that solutions like ours with arcsines in them which hide the ##\pi##'s don't qualify. But, for all I know, maybe there isn't a simpler answer.
Here's an outline of what I did:
Label the centre of the unit square O and the corners ABCD anticlockwise from lower left.
E is the midpoint of AD, F is the point inside the quadrilateral ABOE where the arcs intersect. So BF is length 1 and OF is length 1/2.
The sines of the angles EOF and ABF can be found through a couple of simultaneous equations.
That allows the area ABFOE to be found. The areas of the sectors OEF and BAF are subtracted to find the area of the fillet AFE (following the arcs).
Once this is found, it is reasonably straightforward to determine all the areas in the figure.
[Edit: of course, it would have been a little simpler to find angles DBF and DOF (α and β respectively in the notation at the link below) and get the lune area from those sector areas and that of triangle OFD. It is easy to show that sin(α) = (√14)/8.]
I chased up your reference to quadrable lunes. According to http://www4.wittenberg.edu/academics/mathcomp/bjsdir/TheFiveLunes120408.pdf,there are only five, and none of them look to match the case in this problem. On the other hand, as you say, it does not have to be a quadrable lune for there to be an easy solution.
Is there any chance the picture got changed somewhere along the line? At first glance, it looks rather like Figure 3 at the link I posted just above.
Actually, I don't know, and I do wonder, whether that statement is true. It it's false then, of course, there would be no easy solution to the OP's lune problem.
Consider a degenerate case: the 'lune' is a complete circle. It is not quadrable, but the solution is easy. I feel sure there would be non-degenerate cases with the same feature. If the solution involves pi (irreducibly) then it is not quadrable.
Edit: here's one... two identical circles, each with its centre on the circumference of the other.
Done editing, I think the typos are gone.
Not sure anyone still cares, but here's an approach that I think, plausibly, a bright kid with a little trig might possibly come up with. Let's start with a picture:
The area of the large lens CDFC is the area of the sector BDFC minus the area of triangle BDC. Similarly, the area of the small lens CDGC is the area of sector ADGC minus the triangle ADC. So$$
A_{small~lens} = \frac 1 2 b^2(2\beta - \sin(2\beta))$$ $$
A_{large ~lens} = \frac 1 2 a^2(2\alpha - \sin(2\alpha))$$The area of the upper left blue lune is the difference:$$
A_{lune} = a^2\alpha -b^2\beta + \left(\frac 1 2 b^2\sin(2\beta) -\frac 1 2 a^2\sin(2\alpha)\right)$$Notice that the quantity in the large parentheses is the difference in areas of the triangles ACD and BCD, which is the area of the quadrilateral ADBC, which is twice the area of triangle ABC which has sides a,b, and c. I will call the area of this triangle ##A_t##. So we have$$
A_{lune} = a^2\alpha - b^2\beta + 2A_t$$Now the only reason I think a geometry student might do this is that the area ##A_t## of triangle ABC can be calculated directly from the three sides a,b, and c using Heron's formula, though I would have to look up that formula. And ##\beta## and ##\pi -\alpha## can be calculated from the law of cosines from triangle ABC:$$
\cos\beta = \frac{b^2+c^2-a^2}{2ac}$$ and $$
\cos(\pi - \alpha) = -cos(\alpha) = \frac{a^2+c^2-b^2}{2ac}$$So ##\alpha## and ##\beta## can both be expressed in terms of arccosines and everything can be expressed in terms of a,b, and c.
Likes Samy_A
LCKurtz said:
Not done editing yet, please wait until I'm done...
The area of the large lens CDFC is the area of the sector ADFCA minus the area of triangle CDA. Similarly, the area of the small lens CDGC is the area of sector BCD minus the triangle CDA. So$$
A_{large~lens} = \frac 1 2 b^2(2\beta - \sin(2\beta))$$ $$
A_{small ~lens} = \frac 1 2 a^2(2\alpha - \sin(2\alpha))$$The area of the upper left blue lune is the difference:$$
A_{lune} = b^2\beta - a^2\alpha +\frac 1 2 (b^2\sin2\beta - a^2\sin(2\alpha))$$
I think that's the same as the Edit paragraph in my post #15.
I wasn't done editing yet. Yes, I figured it was similar but I wanted to get everything in terms of the radii and distance between centers, for myself if nothing else.
What is the "Area of Shaded Region" in Elementary Geometry?
The "Area of Shaded Region" in Elementary Geometry refers to the total space covered by the shaded portion of a geometric figure. This is often used to find the area of a figure that has a portion removed or added.
How do you find the "Area of Shaded Region" in Elementary Geometry?
The process of finding the "Area of Shaded Region" in Elementary Geometry involves first finding the total area of the larger figure, and then subtracting the area of the smaller figure or shapes within the larger figure. This will give you the area of the shaded region.
Do you need to know the measurements of the shaded region to find its area?
No, you do not necessarily need to know the measurements of the shaded region to find its area. As long as you know the measurements of the larger figure and the smaller figure or shapes within it, you can use those measurements to find the area of the shaded region.
What are some common figures that involve finding the "Area of Shaded Region" in Elementary Geometry?
Some common figures that involve finding the "Area of Shaded Region" in Elementary Geometry include circles with sectors removed, rectangles with smaller rectangles or circles removed, and triangles with smaller triangles or circles removed.
Why is finding the "Area of Shaded Region" important in Elementary Geometry?
Finding the "Area of Shaded Region" in Elementary Geometry is important because it helps students develop their understanding of basic geometric concepts such as area, perimeter, and shape. It also allows them to apply these concepts in real-world situations, as well as more complex geometry problems in the future.
22K
  • General Math
9K
  • Math POTW for Secondary and High School Students
9K
