Eletric force problem
  • Thread starter zelda1850
zelda1850
66
the magnitude of the electric field strength between two oppositly charged parallel metal plate is 2.0 x 10 3 newtons per coulomb. point p is located midway between the plates.
an electron is located at point p between the plates. caculate the magnitude of the force exerted by the electric field
Felect = k • Q1 • Q2 / d2
k = 9.0 x 109 N•m2
q1 = 2.0 x 10 3
q2 = 2.0 x 10 3
d = missing
how do i figure out the distance for this problem?
Answers and Replies
Mintea
If you've already got the electric field, you don't need a distance; you can just use the fact that F=qE. If your field exerts 2000 Newtons of force on every Coulomb of charge in it, and your particle's charge is -1.6 * 10^-19 Coulombs or whatever (this may not be accurate; I don't exactly know the elementary charge off the top of my head) then you can just plug those in... This help any?
rickz02
49
Coloumbs law can be also be written as [tex]F = qE[/tex].
You are given for the value of the electric field strength and charge of the electron is known to be -1.602e-19 C. Now you can calculate for the electric force exerted on the charge by the field.
Suggested for: Eletric force problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
