Elevator problems
  1. Apr 19, 2013 #1
    So the school is trying to blame, and make us pay for the alleged breaking of an elevator on me and my two friends and we are trying to prove it is not possible. I need some physics help cause my last physics course was in high school. There were 3 of us, weighing 190lbs, 169lbs and 159lbs, respectively, for a total of 518lbs or 234.96 kilograms. They claimed we were jumping so I want to see how high we would have to have jumped in order to go over the weight limit (2,500lbs or 1,133.98 kilograms) and show them it’s not possible for us to have broken the elevator and that it was in bad shape already.
    I figured we could measure the height of the jumps at the following:
    .25ft (.0762m)
    .5ft (.1524m)
    .75ft (.2286m)
    1ft (.3048m)
    I believe those are all the measurements we need, I will be willing to provide any others. Any help appreciated, these repairs may be expensive and we are poor college students.. Faculty just trying to get more money out of us! Thanks all.
  3. Apr 19, 2013 #2
    Put very simply, consdering the total weight limit is alomst 5 times greater than your combined weight, whilst jumping you'd have to push down with a force 4 times greater than your body weight to reach it.
    Try squating 4 times your body weight!
  4. Apr 19, 2013 #3
    Danger
    If the school thinks that it can get away with that BS, you should tell them that you'll sue them for having unsafe equipment. There's no way in the world that you could have broken a certified elevator, so if you did break it, it was already severely defective. They're hooped; go have a celebratory beer (but take the stairs).
  5. Apr 19, 2013 #4
    I can't do the math right now, but indeed if the weight limit of the elevator was 2,500 lbs and there were only 3 of you totaling 518 lbs, I fail to see how you could exceed this limit by jumping. You would not only have to jump high enough to land/ jump with a force of 5 gs, but you would all have to do it simultaneously with a high degree of motivation.
    On top of that, there's usually ridiculous safety factors built into elevators, so that even if you managed to exceed the load it still shouldn't break.
  6. Apr 19, 2013 #5
    Normal modern day elevators , actually I believe they have this feature for a quite a long time have a built in sensor which detects overweight so normally if there would be even a little more weight in the elevator as it's maximum load written on the wall then the elevator should not do anything at all.
    Normally they have a beep sound or something like that when you put too much weight in them they just stop and do nothing.
    Ofcourse jumping in an elevator puts additional stresses on the mechanical parts of the elevator but let's be honest if elevators would break that easy then highrise structures would be literally impossible but they do not break that easily unless ofcourse they are used as hell and not seen a maintenance in many many years.
  7. Apr 19, 2013 #6
    russ_watters
    Staff: Mentor
    So you were jumping when it broke, right?
  8. Apr 19, 2013 #7
    jbriggs444
    Probably you were jumping in rhythm attuned to the elevator's resonant frequency. That means that it's not just you bouncing up and down putting strain on the cables. It's the elevator itself. Estimates of how much force you can put on the floor are not directly relevant -- that's just how hard you're driving the oscillation. It's the force of the oscillation on the cables that's relevant.
  9. Apr 20, 2013 #8
    A.T.
    Did it actually break, or was some security lock enabled, that has to be disabled by a technician?
  10. Apr 20, 2013 #9
    Danger
    Any certified elevator (in North America) has 4 or 5 support cables, any one of which is sufficient to support the rated load. There are also flywheel governors and rail clamps that will instantly halt a fall. If the label says that the limit is 2,500 lbs., you would have to have imparted an impact loading of at least 10,000 lbs. in order to cause any damage to the cables. I don't know what the overage for the structure of the car is, but it is most assuredly a lot more than the rated limit. You'd need a lot more friends, and maybe a pet hippo, to break anything.
  11. Apr 20, 2013 #10
    yeah, with my calculations we would need 2 more people and we would all need to jump at least 6 inches all at the same time to be over the limit. and mind you, 6 inches is a pretty healthy jump
    and after telling us it would take another week to fix blah blah blah, they fixed it yesterday
  12. Apr 20, 2013 #11
    russ_watters
    Staff: Mentor
    So it broke while you were jumping on it. Your fault, whether it should have broken or not. In any case, resonance is a possible explanation, as jbriggs said. When people feel something bouncing, they have a tendency to purposely bounce with it. And if you did that, you could have easily exceeded the load limit.
  13. Apr 20, 2013 #12
    sophiecentaur
    2017 Award
    Let's face it chaps. You were messing about in the lift and trying to wreck it. You deserve to get your butts kicked. They should suspend you or leave you in the lift for an unspecified time till you grow up. Don't come to PF for sympathy.
  14. Apr 20, 2013 #13
    The resonant behaviour is interesting as it may be the three of you could get get the lift into resonance and exceed the 2500lb limit, it has happened many times in bridges where synchronous excitation of people transversing it cause resonant problems. Take the Albert Bridge which actually has a sign stating that troops must break step whilst crossing the bridge. They closed the Millenium Bridge for similar reasons.
    Maybe a key point here is "was there a sign in the lift saying - NO jumping". Never seen one myself but if there is - busted.
    Doing the maths it would seem with a 5g jump you would hit the roof and counter much of the implied downward force with an upward impact and hurt your head.
    But one must also question why one would want to synchronously excite a lift, damage it and maybe even fall down the lift shaft - so many questions unanswered.
  15. Apr 21, 2013 #14
    I think if we take the resonance problem here into account we would have to know how high the elevator itself is , not even precisely but approximately how many floors or levels it covers.
    Because if the elevator is kinda "small" like the ones used in a three to four storey buildings then the corresponding cables are also pretty short and the jumping would have a pretty small if any effect.
    The resonance problems usually come into play on long or high structures like long bridges , elevators or structures were long supporting columns and or cables are used.
    But for the height of the elevator I guess the OP is the most competent person around here ...
    P.S. sophiecentaur reading your comment I do get the feeling that you have dealt with such a case at some point in your life.
    Nevertheless I agree that too liberal of a system and attitude from authorities of any kind is sometimes even a more devastating thing than a totalitarian authority or government...
    Although this is a suit yourself argument.
  16. Apr 21, 2013 #15
    A.T.
    Now I'm not a fancy big city lawyer, but...
    They were performing physics experiments.
    Was there a sign in the lift explicitly prohibiting jumping around? Jumping around is part of normal behavior of kids. An elevator in a school should be jump proof.
  17. Apr 21, 2013 #16
    sophiecentaur
    2017 Award
    @AT
    So how much do we have to spend on cotton wool, to protect kids from the consequences of daft behaviour? Why should there be a list of dos and donts on every piece of equipment? If a school trampoline broke when they were jumping on it, would they have been told off?
    The OP is just trying a 'technical' defence when it was just a matter of a stupid act. I tried the same thing when I was caught for a bit of silly vandalism at the age of 12. The Head gave me four whacks on my backside and rightly so. Less harm in the long run than some liberal response. I haven't been moved to vandalism since.
  18. Apr 21, 2013 #17
    sophiecentaur
    2017 Award
    @AT
    So how much do we have to spend on cotton wool, to protect kids from the consequences of daft behaviour? Why should there be a list of dos and donts on every piece of equipment? If a school trampoline broke when they were jumping on it, would they have been told off? no. Someone would have been in the wrong for a bad maintenance regime.
    I must say, that all reads as a bit more Redneck than I meant it to but I'll go with it.
  19. Apr 21, 2013 #18
    A.T.
    Silly hyperbole, an elevator floor is something you are allowed to walk on. If it was an old wooden staircase that broke down, would you also blame the kids for running on it, instead of walking slowly and cautiously.
    If the elevator cannot stand jumping, don't allow kids to use it. This will solve the obesity problem too.
  20. Apr 21, 2013 #19
    Well quite honestly both sides are guilty , the kids for jumping where normally one should just stand to wait when the door opens and then they can walk out and go wherever they desire to, and the elevator for that it broke down.
    It sounds silly but things can break down at the most unimaginable ways even when used normally , it's a matter of many many factors that we cannot even keep trace of so we have insurance companies for cases like these where no real physical proof of ones bad intentions can be found to be the real cause of the accident , although very likely it was.
  21. Apr 21, 2013 #20
    People will jump on elevators. That's what people do. Hell, the elevator in my very building got stuck and I had to call help because a guy I know, an adult male at that, was jumping in it. An overweight adult male. An overweight adult male who's a professor at the Eindhoven University of Technology.
    Yeah, maybe he had a bit to drink, but an an elevator should be designed to cope with that. If we can put a man on the moon, we should be able to build an elevator to handle some kids jumping.
    There are no stupid people, just stupid designs.
Similar Discussions: Elevator problems
Loading...
