Ellipses homework help
  • Thread starter physicsgal
an ellipse is represented by the equation:
x|^2 + 4y^2 - 4 x + 8y - 60 = 0
express the equation in standard form:
((x-2)^2 / 68) + ((y-4)^2/17) = 1
can anyone tell me if this is accurate? thanks
~Amy
Answers and Replies
G01
That isn't what I'm getting. Can I see your work?
thanks!
i wont show all of it (half page long), but here's the main parts:
x^2 - 4x + 4y^2 + 8y = 60
(x^2 - 4X + 4) + (4(y^2 - 2y + 1) = 68
(i got the 68 by added 60 + 4 + 4(1))
~Amy
G01
OK, I get:
[tex]\frac{(x-2)^2}{68}+\frac{(y+1)^2}{17}=1[/tex]
I think your mistake lies when you factored out that four and simplified, check your work.
thank you very much!
i have another quick question:
an elliptical pool table is 5m at its longest point, and 3m wide at its widest point. the pool table has two holes at the position of the foci.
so for the equation i have figured out:
x^2/6.25 + y^2/2.25 = 1.
and the foci are at (-1, 0), (1,0)
(im pretty sure all this is accurate, but anythings possible).
the question asks:
"if a pool ball is hit from one focus, it will bounce once and enter the hole at the other focus. will the ball always travel the same distance if it is hit from one focus? if so, what is the distance it will travel? prove your statement by selecting any point (except one of the vertices) on the edge of the pool table."
i know how to figure out how to get one of the points on the edge of the pool, but what next?
~Amy
symbolipoint
Education Advisor
1,276
Good work, ~Amy,
your solution must have been equivalent to:
[tex] % MathType!MTEF!2!1!+-
% feqaeaartrvr0aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn
% hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l
% bbf9q8WrFfeuY-Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0-yr0R
% Yxir-Jbba9q8aq0-yq-He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa
% caGaaeqabaaaamaaaOabaeqabaGaamiEamaaCaaaleqabaGaaGOmaa
% aakiabgkHiTiaaisdacaWG4bGaey4kaSIaaGinaiaadMhadaahaaWc
% beqaaiaaikdaaaGccqGHRaWkcaaI4aGaamyEaiabgkHiTiaaiAdaca
% aIWaGaeyypa0JaaGimaaqaaiaadIhadaahaaWcbeqaaiaaikdaaaGc
% cqGHsislcaaI0aGaamiEaiabgUcaRiaaisdadaqadaqaaiaadMhada
% ahaaWcbeqaaiaaikdaaaGccqGHRaWkcaaIYaGaamyEaaGaayjkaiaa
% wMcaaiabgkHiTiaaiAdacaaIWaGaeyypa0JaaGimaaqaamaabmaaba
% GaamiEamaaCaaaleqabaGaaGOmaaaakiabgkHiTiaaisdacaWG4bGa
% ey4kaSYaaeWaaeaacaaI0aGaai4laiaaikdaaiaawIcacaGLPaaada
% ahaaWcbeqaaiaaikdaaaaakiaawIcacaGLPaaacqGHsisldaqadaqa
% aiaaisdacaGGVaGaaGOmaaGaayjkaiaawMcaamaaCaaaleqabaGaaG
% OmaaaakiabgUcaRiaaisdadaqadaqaaiaadMhadaahaaWcbeqaaiaa
% ikdaaaGccqGHRaWkcaaIYaGaamyEaiabgUcaRmaabmaabaGaaGOmai
% aac+cacaaIYaaacaGLOaGaayzkaaWaaWbaaSqabeaacaaIYaaaaaGc
% caGLOaGaayzkaaGaeyOeI0IaaGinamaabmaabaGaaGOmaiaac+caca
% aIYaaacaGLOaGaayzkaaWaaWbaaSqabeaacaaIYaaaaOGaeyOeI0Ia
% aGOnaiaaicdacqGH9aqpcaaIWaaabaWaaeWaaeaacaWG4bGaeyOeI0
% IaaGOmaaGaayjkaiaawMcaamaaCaaaleqabaGaaGOmaaaakiabgkHi
% TiaaisdacqGHRaWkcaaI0aWaaeWaaeaacaWG5bGaey4kaSIaaGymaa
% GaayjkaiaawMcaamaaCaaaleqabaGaaGOmaaaakiabgkHiTiaaisda
% cqGHsislcaaI2aGaaGimaiabg2da9iaaicdaaaaa!8D64!
\begin{array}{l}
x^2 - 4x + 4y^2 + 8y - 60 = 0 \\
x^2 - 4x + 4\left( {y^2 + 2y} \right) - 60 = 0 \\
\left( {x^2 - 4x + \left( {4/2} \right)^2 } \right) - \left( {4/2} \right)^2 + 4\left( {y^2 + 2y + \left( {2/2} \right)^2 } \right) - 4\left( {2/2} \right)^2 - 60 = 0 \\
\left( {x - 2} \right)^2 - 4 + 4\left( {y + 1} \right)^2 - 4 - 60 = 0 \\
\end{array}
[/tex]
GO1 put his information up before I could.
symbolipoint
Education Advisor
1,276
I tried to post a solution process but the LaTex did not work (it used to work)
symbolipoint
Education Advisor
1,276
\eqalign{
& x^2 - 4x + 4y^2 + 8y - 60 = 0 \cr
& x^2 - 4x + 4\left( {y^2 + 2y} \right) - 60 = 0 \cr
& \left( {x^2 - 4x + \left( {4/2} \right)^2 } \right) - \left( {4/2} \right)^2 + 4\left( {y^2 + 2y + \left( {2/2} \right)^2 } \right) - 4\left( {2/2} \right)^2 - 60 = 0 \cr
& \left( {x - 2} \right)^2 - 4 + 4\left( {y + 1} \right)^2 - 4 - 60 = 0 \cr}
[/tex]
G01
I'm not sure about this second question yet Amy, I'll work on it though.
thanks for your help :eek:) talk to you tomorrow.
~Amy
symbolipoint
Education Advisor
1,276
~Amy
For your post #5,
b^2 = a^2 - c^2
Yes, the ball will travel the same distance from one focus to the other nomatter from which direction it leaves the initial focus.
I guess 2a=5 and 2b=3. So the equation pans out to [tex]\frac{x^2}{2.5^2}+\frac{y^2}{1.5}^2=1[/tex], and what they're asking for is that the sum of the distances from the foci... this is a constant, you can prove this by finding the distance of any arbitrary point from the two directrixes, and using the relation ps=e.pm, where s is the focus, and M is a point such that pm is perpendicular to the directrix.... this works out to be 2ae, where e is the eccentricity of the ellipse.
thanks chaoeverlasting, but i didnt quite understand everything you said.
here's what ive done:
if x = 1, y = 1.37 (1, 1.37)
foci (-2, 0), (2, 0)
d = *square root*(x2 - x1)^2 + (y2 - y1)2
( i do this for (1, 1.37) and (-2, 0). and then for (1, 1.37) and (2, 0))
= 3.30, and 1.70
but they should both equal the same thing.. does anyone see where i went wrong?
thanks
`Amy
Related Threads on Ellipses homework help
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
