Is is possible for us to change the frequency of a wave?
In summary, it is possible for us to change the frequency of a wave. Gamma waves are as high as they get, but there may be higher frequency EM radiation. Cosmic rays are high energy photons that come from space and when they enter the atmosphere cause "cosmic ray air showers".
Jack
108
Is there an electromagnetic wave with a higher frequency than that of of gamma rays?
I think gamma waves are as high as they get, but I'm not sure.
The frequency of a wave can be changed through interaction wih gravity or doppler shift. I think those are the only ways.
Most EM spectrum tend to cut off at gamma rays since that's about the most energetic radiation we see, but in principle you could have EM radiation with smaller wavelengths.
Am guessing that you're not referring to reradiated EM waves (e.g. light is absorbed by some material and then reradiated at a lower frequency OR sum frequency generation), nor some experimental laser techniques where you're working with entire pulses of laser light, so am not sure otherwise on the second part of the original post.
The term 'gamma' refers to any EM radiation with energy greater than about 100 keV. It is unbounded -- any photon with energy > 100 keV is gamma radiation.
- Warren
What is heat radiated out from a hot object as?
You can easily calculate the peak of the blackbody spectrum for any given temperature; that will give you a rough idea of the dominant frequency radiated by any thermal body at that temperature.
- Warren
Chroot, don't you do that by using Wien's law? Then you can just do Peak Wavelength=(2.9*10^7)/T. T is in kelvins, and then the peak comes out in angstroms.
There are higher energy photons beyond gamma rays, they are called cosmic rays, some people put that in the same class as gamma though, but some sources set it apart. Whatever, its a matter of semantics, but if you're used to thinking of a gamma ray as something that we can produce on Earth then you should know that in this cosmic ray regime, you can't produce them with any machine yet. They come from space and when they enter the atmosphere cause "cosmic ray air showers" which is a shower of muons electrons and other stuff that comes down to the surface when the photon collides with an atom in the upper atmosphere. There is a very small flux of really really really high energy cosmic ray that is so high energy that physicists have trouble explaining where it comes from because no known mechanism in the universe should be able to produce such energetic photons.
For more info on the very high energy cosmic rays that grady is talking about please check out this site from my universities website. This project which is responsible for observing that "very small flux of really really really high energy cosmic rays" was kind of spurred on by my department and is one of their big proud achievements. They have lectures on it all the time here, its really pretty neat.
1. Can we change the frequency of any type of wave?
Yes, it is possible to change the frequency of any type of wave, including light waves, sound waves, and electromagnetic waves.
2. How can we change the frequency of a wave?
The frequency of a wave can be changed by altering the source of the wave or by manipulating the medium through which the wave travels. For example, the frequency of a sound wave can be changed by adjusting the pitch of the source or by changing the density of the medium it travels through.
3. Is it difficult to change the frequency of a wave?
The difficulty of changing the frequency of a wave depends on the type of wave and the method being used. Some methods, such as adjusting the source, may be relatively simple, while others, such as manipulating the medium, may require more advanced technology or techniques.
4. Can we control the frequency of a wave?
Yes, we can control the frequency of a wave by using various techniques and technologies. For example, radio and television signals use specific frequencies that can be controlled and changed to transmit information.
5. Why would we want to change the frequency of a wave?
Changing the frequency of a wave can have practical applications in various fields such as communication, medicine, and technology. For instance, controlling the frequency of light waves is essential in optical communication, and changing the frequency of sound waves is crucial in ultrasound imaging.
  • Other Physics Topics
