Are Conventional Physics Models Enough to Explain Emergent Theories in Physics?
In summary: Secondly, what exactly is meant by "... strictly known, conventional physics..."? I may not use the same elementary particles, but the physics and mathematics may look the same when I apply it to a slab of superconductor. So have I applied the same "strictly known, conventional physics"? Would a model in economics having the same form as an equation in QFT be considered as applying the same "strictly known, conventional physics"?From the perspective of a model, the equations in standard physics and general relativity are equivalent.I'm not asking about examples where it is easy to see that the laws of observed phenomena can be easily reduced to an appoximation of an underlying, more fundamental
giulio_hep
104
Let me write a brief intoduction to my question, just to clarify what I am not asking here, since it has been already discussed elsewhere.
[1] intro
Well, it is well known how the classical world of our experience can emerge from quantum mechanics in terms of decoherence. But it doesn't seem to me the only approach to generalization and emergence.
Another well known example is how we obtain classical physics by taking the limit of Planck's constant to zero, and simlarly with relativity and other deformations (where the classical limit involves small speeds or a small mass size, etc...)
[2] typical renormalization approach and its limits
Unlike in systems biology, physics is dominated by effective models and theories.
This is in large part due to the great success of continuum limit arguments and RG procedures.
The problem is that - while renormalization group operates on field theories with a scale invariance or conformal symmetry - biochemical networks - and all what constitute the classical world - are particularly challenging due to inhomogeneity and lack of symmetries.
[3] my question
Machine learning methods that search for real world patterns are a growing feature of our recent research methods. In fields like ecology, systems biology, and macroeconomics, grossly simplified models capture important features of the behavior of incredibly complex interacting systems.
In contrast to carefully and independently measure each parameter, we can instead constrain the model parameters with system-level measurements that are similar to the types of measurements we wish to predict. And somewhat counterintuitively, from the perspective of sloppy models, working to estimate precise parameter values in a model is useless while instead useful predictions of interest can be made without precisely knowing any single parameter.
Therefore my question is how can you exclude that observed, effective laws (of chemistry, biology, etc) are - at least partially - independent from the strictly known, conventional physics (e.g standard model and general relativity) models?
Unfortunately, I am still unclear on what you are NOT asking.
For example, how is what you're asking different than what has been written by Phil Anderson and Bob Laughlin on the nature of the emergent phenomena? We don't really have to go to biological system or chemistry to seek such phenomena, since condensed matter physics is made up of nothing but emergent phenomena.
Zz.
Biology is purely based on effective models.
What do you mean by "independent"? If we modify the standard model, e.g. make the free neutron stable and the free proton unstable by changing quark masses, biology would not even exist. That looks like a strong dependency.
Likes Dale
We can't - it is impossible to prove a negative of that sort.
However, in the absence of any convincing example of a phenomenon that is not completely explained by "conventional physics" there's no reason to assume that such explanations are needed. Furthermore, the past experience with this line of thought has been discouraging - over the past few centuries physics has demonstrated ever-greater explanatory success across an ever-wider range of problems.
Likes giulio_hep
I'm not asking about examples where it is easy to see that the laws of observed phenomena can be easily reduced to an appoximation of an underlying, more fundamental theory.
As far as emergence is interpreted as opposite to reductionism, it can be that what I'm asking is somehow not different from the above quote and it could be shortened to a simple 'why not?'
In this sentence you seem to misunderstand me maybe and it looks like contrary to the previous one: emergent phenomena meaning not reducible... so we have to go to biological system since condensed matter could be more reasonably reduced indeed.
ZapperZ said:
Would a model in economics having the same form as an equation in QFT be considered as applying the same "strictly known, conventional physics"?.
No, it would NOT. I'm not looking for the same math description, but for the very same physical derivation.
I also think that this is the expected answer. I understand that there's no reason to assume that such explanations are needed, but I was asking if we can absolutely exclude they are (and I guess we can't, in line of principle ).
But not effective with the same meaning given in physics: you can't prove they're an approximation of a more general physics law.
mfb said:
.What do you mean by "independent"? If we modify the standard model, e.g. make the free neutron stable and the free proton unstable by changing quark masses, biology would not even exist. That looks like a strong dependency.
The other way around. I'm asking if they are partially independent. You are proving that they are not fully independent.
This is unclear. What, in your opinion, is "fundamental theory"? To me, CPT symmetry is a "fundamental theory", and it applies even to emergent phenomena!
As far as emergence is interpreted as opposite to reductionism, it can be that what I'm asking is somehow not different from the above quote and it could be shortened to a simple 'why not?'In this sentence you seem to misunderstand me maybe and it looks like contrary to the previous one: emergent phenomena meaning not reducible... so we have to go to biological system since condensed matter could be more reasonably reduced indeed.
Whoa! Really?
Then please show me how superconductivity can be derived from the reductionist starting point. And before you do that, please read Bob Laughlin's Nobel Prize lecture first.
I have no idea what this means.
Zz.
We cannot exclude them as a matter of principle, but "no reason to assume such explanations are needed" is a sufficient reason to exclude them from discussion in a forum dedicated to empirical science.
I am closing this thread. As with any such closing, PM me if you have something to add to the discussion so far.
Likes Dale
1. What are emergent theories in physics?
Emergent theories in physics refer to the idea that complex and novel behaviors can arise from the interactions of simple elements within a system. These behaviors are not explicitly programmed or designed, but instead emerge as a result of the system's structure and dynamics.
2. How do emergent theories challenge traditional physics?
Emergent theories challenge traditional physics by suggesting that the reductionist approach of breaking down complex systems into their individual components may not fully explain the behaviors and phenomena observed in the real world. Instead, emergent theories focus on the interactions and relationships between these components.
3. What are some examples of emergent theories in physics?
One example of an emergent theory in physics is the study of self-organizing systems, such as flocking behavior in birds or schooling behavior in fish. Another example is the theory of emergence in complex networks, which studies how the structure and connectivity of networks can give rise to collective behaviors.
4. How do emergent theories contribute to our understanding of the universe?
Emergent theories contribute to our understanding of the universe by providing new perspectives and insights into complex systems and phenomena. They also help to bridge the gap between fundamental physics and the complex behaviors observed in the natural world.
5. What are the potential applications of emergent theories in physics?
Emergent theories have a wide range of potential applications, including in fields such as biology, economics, and sociology. They can also be applied to engineering and technology, such as in the development of self-organizing systems and artificial intelligence.
  • Quantum Interpretations and Foundations
  • Other Physics Topics
13K
  • Beyond the Standard Models
