Calculating EMF in a Current Loop: 1000 Revolutions/Min with B = 0.45 T"
In summary, the group is discussing a problem involving a rectangular coil and its speed of rotation in a uniform magnetic field. The given dimensions of the coil are 75mm in width and 100mm in length. The question asks for the speed of rotation if an rms voltage of 0.25V is developed in a magnetic field of 0.45T in the z-direction. The correct answer is 1000 revolutions per minute. The conversation also includes a discussion on equations and the use of symbols, as well as the relevance of the coil's axis of rotation and the angle between the z-axis and the normal of the coil's plane.
zerobladex
Hi all,
I have a certain problem I'm getting stuck on hopefully someone here can help
A rectangular coil is 75 mm wide in the y-axis, 100mm long in the x-axis. What is the speed of the rotation if an rms voltage of 0,25 V is developed in the uniform field of B = 0.45 T in the Z direction.
The correct answer is supposed to be 1000 revolutions/min.
emf = d[flux]/dt
*Sorry a little unsure of how to use the symbols and such
I honestly am not sure where to start. Normally i would try to find the expression for magnetic flux, plug in the numbers and solve for the frequency, but it doesn't work so in this case.
Vpeak = (√2)·Vrms
The Peak Voltage is seen when dΦ/dt is maximum.
Does it matter whether the axis of rotation of the coil is along the x-axis or along the y-axis? No.
Suppose the loop is centered at the origin and the angle between the z-axis and the normal to the plane that the loop lies in is θ. Then the magnetic flux is ΦB=B·A·cos(θ).
dΦ/dt = ‒B·A·sin(θ)·(dθ/dt) .
1. How do you calculate the EMF in a current loop?
The EMF (electromotive force) in a current loop can be calculated using the formula: EMF = -N * ΔΦ/Δt, where N is the number of turns in the loop, ΔΦ is the change in magnetic flux over time, and Δt is the time interval.
2. What is the significance of 1000 revolutions per minute in this calculation?
In this calculation, 1000 revolutions per minute refers to the rate at which the current loop is rotating. This information is important because it determines the value of Δt (time interval) in the EMF formula.
3. What is the value of B in this calculation?
In this calculation, B refers to the strength of the magnetic field in which the current loop is rotating. The value of B is given as 0.45 T (Tesla).
4. How does the number of turns in the loop affect the EMF?
The number of turns in the loop (N) directly affects the EMF, as shown in the EMF formula. Increasing the number of turns will result in a higher EMF, while decreasing the number of turns will result in a lower EMF.
5. Can this calculation be used for any current loop with different values?
Yes, the EMF calculation can be used for any current loop as long as the values of N, B, and the rate of rotation (Δt) are known. These values can vary for different current loops, but the same formula can be applied to calculate the EMF.
