Explore EMF Induction: Why & How It Occurs
In summary, the induction of emf in a moving conductor is due to the Lorentz force on the mobile charges in the conductor. To determine which wire in an A.C. generator is live, it is necessary to ground one wire and fuse the other. The reason for grounding is to limit the potential to ground, as ungrounded power sources can have a dangerous potential. However, if the system is floating, the risk of electric shock is lower. In the case of a bathroom receptacle, using an isolating transformer can limit the risk of shock.
DeathKnight
73
emf induction...
Why does a moving conductor becomes induced with an emf? Well I know it has to do something with changing magnetic flux. The thing I want to know is why the changing magnetic flux leads to e.m.f. induction?
Secondly, we have an A.C. generator in which the coil is rotated to produce the current. I'm given the task to connect a fuse to one of the wires leading out of the generator. How would I which one is live wire and which one is neutral considering that the direction of the currect is continuosly changing?
Thanks in advance for any help. :approve:
Why is not a real good question in physics, unless you are able accept Maxwells equations as a reason why. The understanding of how a current is induced will come with an understanding of Maxwell. In the truest sense of the word WHY, we can only say, because it does.
As for the problem with your fuse, there is now way that question can be answered without a schematic diagram of the wireing of the geneator. How can we possibly answer a question about specific hardware without documentation? You will need to ask the designer or the plant engineer about that.
the change of B-field lead EMF is like the change of momentum leads force
One way to understand how an emf is induced in a moving conductor (IN A MAGNETIC FIELD!) is to recognize that the conductor is made up of electrons and ions. Charges that move in a magnetic field are subject to the Lorentz force which tends to push electrons in one direction and ions in the other direction. The ions are essentially fixed (lattice) while the electrons are mobile. In effect this causes a charge separation thereby inducing a potential difference across the conductor with the resulting electric field eventually balancing the Lorentz force.
A stand alone generator (or alternator) with all leads isolated is considered a "floating" power supply. If the output voltage is 115 you can ground either one and fuse the other. If it's 230 volts, there should be a center tap (neutral) that can be grounded, then fuse the other 2 leads.
The reason for grounding is to limit the potential to ground; an ungrounded 115 volt alternator could read 1000 volts or more to actual ground, creating a dangerous condition.
Well, Here is a simple generator with wiring. What do you say now?
I am not going to say what I am thinking.
Put the fuse in the load line.
Is it too complicated or is my question too dumb?
The drawing you provided is not a schematic of an operating generator. In that drawing there is only one possible place for a fuse. It must go in the load line. But that does not answer the question you asked. Which seemed, to me, to be a specific quesition about a specific generator. A fuse must be placed in a current carrying load line is the general answer.
wire2 said:
...The reason for grounding is to limit the potential to ground; an ungrounded 115 volt alternator could read 1000 volts or more to actual ground, creating a dangerous condition.
Incorrect as written. To be dangerous, there must be a complete current path from the voltage source, through the load (person), and back to the voltage source. Additionally, what would create the 1000 volt potential?
It's written from experience. A defective tool or appliance can have exposed parts live. Simply holding one while standing on concrete with leather soled shoes will complete the circuit. Many people have felt an electrical shock this way at one time or other.
An ungrounded power source, be it a Y connected transformer secondary or a portable generator, can have the potential float to an unsafe level (compared to actual ground) if there's no physical connection through a resistor or lamp to reference it.
Many years ago bathroom receptacles were fed through a 115/115 volt isolating transformer to limit the risk of electric shock. Touching one side or the other would pull that side to zero volts (if touching the sink or taps).
One more example, you run a portable generator (which has rubber vibration mounts and feet). With a high input resistance meter, measure between a real ground (steel fence post etc.) and the hot lead of the generator. It might read 115 volts, or 60, or 0, or 500. There's no real reference.
If the system is referenced to ground that is indeed the case. If the system was floating, the circuit path is not complete, thus near zero current flow through the person. The small current is a result of small capacitance coupling to the Earth but never the less; the current would be limited to a few micro amps and not hazardous. This is why a floating system is safer than a ground referenced system as in your example…
wire2 said:
Many years ago bathroom receptacles were fed through a 115/115 volt isolating transformer to limit the risk of electric shockTouching one side or the other would pull that side to zero volts (if touching the sink or taps).
In the above example, to receive a perceptible shock, it is necessary for one or the other terminals to be connected to ground (converting it to a ground referenced system) before one can receive a perceptible shock by contacting the other terminal and ground.
Linemen routinely service multi-kilovolt power distribution systems and do so safely as long as they are not in contact with either of the other two phases or ground and not within the arc-over distance. Again, if there is not a complete circuit, no perceptual current will flow; just ask the birds.
Electricians I’ve spoken to sometimes refer to the voltage readings as “phantom” voltage and they realize the measurement is of no consequence. Many electricians prefer the old analog, low input impedance voltmeters so as not to be confused by these readings. If one places a 10kohm resistor across the terminals of the modern DVM, the phantom reading will disappear. The 10kohm resistor across the terminals makes the system neither more nor less safe than it was previously, it simply lessens the value of an irrelevant reading. Lastly and again, a complete circuit must be realized before perceptual current can flow.
What is EMF induction?
EMF induction is the process by which an electrical current is induced in a conductor when it is exposed to a changing magnetic field. This phenomenon occurs due to the interaction between the magnetic field and the electrons in the conductor.
Why does EMF induction occur?
EMF induction occurs because of Faraday's law of induction, which states that a changing magnetic field will induce an electrical current in a conductor. This is because the changing magnetic field causes a force on the electrons in the conductor, resulting in the flow of electricity.
What are the factors that affect EMF induction?
The strength of the magnetic field, the rate of change of the magnetic field, and the properties of the conductor (such as its shape, size, and material) are all factors that can affect EMF induction. Additionally, the presence of other conductors or magnetic materials nearby can also impact EMF induction.
How is EMF induction used in everyday life?
EMF induction is used in many everyday devices, such as generators, transformers, and electric motors. It is also used in wireless charging technologies and in the production of electricity through renewable energy sources like hydroelectric and wind power.
What are the potential dangers of EMF induction?
EMF induction can potentially be harmful to living organisms if they are exposed to high levels of electromagnetic fields. This is why safety standards and regulations have been put in place to limit exposure to EMF in certain industries and settings. However, the levels of EMF typically encountered in everyday life are not known to cause any harm to humans.
  • Electromagnetism
  • Electromagnetism
14K
