EMI - voltage across Inductor
cupid.callin
1,137
suppose there is a inductor connected to a battery and resistor in series ...
i need to find the current in circuit at some time t
i suppose i could use Kirchhoff's loop law but i dont know weather to take potential across inductor (L di/dt) as positive or negative.
i suppose i should use it as negative because it is opposing the emf of battery but i am not sure
but this thing will not work in case of discharging LR circuit ... some help please ... ... ... ...
Answers and Replies
collinsmark
1,929
You can figure this out. :smile:
Suppose there is no initial current. In other words, suppose the circuit is such that at time t = 0, the circuit is closed and i0 = 0 (at that instant in time).
Now sum the voltages all the way around in a loop. You'll have to calculate the voltage drop across R, but that should be pretty easy since at this instant in time, i = 0. Then note that the sum of all the voltage drops, all the way around the loop should equal zero, per one of Kirchhoff's laws.
So what polarity does the voltage across the inductor have to be to insure that Kirchhoff's law(s) are satisfied?
ehild
15,543
1,915
The potential refers to a point. Potential difference is "across".
In an inductor, an is emf induced due to changing current. It is -L dI/dt. You can consider it as an additional voltage source that has opposite sign as that of the "real" source.
ehild
cupid.callin
1,137
ehild
i can do this to find the sign but i need the reason that why is sign like that ...
and sorry for late reply .....
ehild
15,543
1,915
It is the consequence of Maxwell's laws. They are the fundamental laws of electrodynamics, based on experimental facts. You cannot ask, why.
ehild
cupid.callin
1,137
why not ... everything in physics has a reason ,,, weather we know it or not
ehild
15,543
1,915
Well, you can think that in case the opposite were true, and positive electromotive force were induced by a changing current, the induced emf would rise the current even more in a circuit and the circuit would blow away. If such law existed in the history of the universe in some world, that world would not have been stable and can not exist now.
ehild
Suggested for: EMI - voltage across Inductor
  • Last Post
  • Last Post
11K
  • Last Post
  • Last Post
9K
25K
  • Last Post
  • Last Post
23K
