What is the relationship between temperature and emissive power for a gas?
  • Thread starter lumberbunny
  • Tags
    Gas Power
In summary, the emissive power of a gas is dependent on its temperature. There is no conceptual generalization for the radiation of power from a partially transparent material, such as gas, and a specific emission spectrum must be chosen. The total power emitted from a sphere of gas at a given temperature is bounded by the power emitted by a blackbody of the same size. The actual power emitted is related to the properties of the gas. Additionally, if there is a finite mass of the gas with a normal distribution, the total emitted power can be calculated from very far away from the center.
lumberbunny
How does the emissive power for a gas depend on temperature? Is there a conceptual generalization (along the lines of Planck's Law) for the radiation of power from a partially transparent material or must a specific emission spectrum be chosen?
Thanks
Okay, after rereading it I notice that my original post is a little lacking in detail, so let me form it into a more concrete problem:
Say that there's a sphere of radius R surrounded by empty space but fill with gas X and at temperature T. What is the total power emitted to the surrounding space and what are the relevant properties of the gas?
I assume that any possible answer is bounded by the power emitted by a blackbody of the same size, but how is the actual power related to the properties of the gas?
Now, turning it up a notch, say there's is a finite mass M of the gas normally distributed with standard deviation S. What is the total emitted power from the mass when seen very far from the center?
for your question. The relationship between temperature and emissive power for a gas is described by the Stefan-Boltzmann law, which states that the emissive power of a blackbody (a perfect emitter and absorber of radiation) is directly proportional to the fourth power of its absolute temperature. This means that as the temperature of a gas increases, its emissive power also increases exponentially.
The emissive power for a gas depends on temperature through the thermal motion of its molecules. At higher temperatures, the molecules have more kinetic energy and move faster, leading to an increase in the emission of electromagnetic radiation. This is because the molecules are able to emit more photons due to their increased energy levels.
There is a conceptual generalization for the radiation of power from a partially transparent material, known as the Kirchhoff's law of thermal radiation. This law states that the emissivity of a material is equal to its absorptivity at a given wavelength and temperature. In other words, a material that is a good absorber of radiation at a certain wavelength will also be a good emitter at that same wavelength and temperature.
However, for a partially transparent material, the emission spectrum will depend on its composition and structure. This is because different materials have different energy levels and can absorb and emit radiation at different wavelengths. Therefore, a specific emission spectrum must be chosen for a partially transparent material, rather than a conceptual generalization like Planck's law.
What is emissive power for a gas?
Emissive power for a gas is the ability of a gas to emit thermal radiation. This radiation is usually in the form of infrared energy and is produced by the movement of molecules in the gas.
How does emissive power vary with temperature?
Emissive power for a gas increases with temperature. This is because as the temperature of a gas increases, the molecules within the gas move more rapidly, causing an increase in the amount of thermal radiation emitted.
What factors affect the emissive power of a gas?
The emissive power of a gas is affected by several factors, including temperature, pressure, and the composition of the gas. The type of molecules and their energy levels also play a role in determining the emissive power of a gas.
What is the relationship between emissive power and absorbance?
Emissive power and absorbance are directly related. A gas with a high emissive power will also have a high absorbance, meaning it can both emit and absorb thermal radiation at a high rate.
How is emissive power measured?
Emissive power for a gas is typically measured using a spectrophotometer, which measures the amount of thermal radiation emitted by the gas. This measurement can then be used to calculate the emissive power of the gas at a given temperature.
  • Quantum Physics
  • Quantum Physics
  • Astronomy and Astrophysics
  • Quantum Physics
  • Materials and Chemical Engineering
  • Quantum Physics
