Build an EMP Without Explosives: Step-by-Step Guide Using Capacitors | XSNIDALX
  • Thread starter XsnidalX
  • Tags
    Capacitors
In summary, the EMP subject did not help me and I would like to know what kind of monitor it was and where you got the 400 Volt ones.
XsnidalX
Hello, I've read an EMP subject on this site a few minutes ago, it' didn't help me anything at all.
My buddy had built an EMP with Capacitors and no explosive materials, how would i do it?
Im thinking of building one, without explosives, because that's just too dangerous and not a smart idea.
Can you please help me, or tell me how to build one, specifically.:smile:
I have a few 200 Volt Capacitors in the Monitor i took apart, and i have a couple 400 Volt ones.
Thankyou
XSNIDALX
I don't know much about your problem but I would like to know what kind of monitor it was and where you got the 400 Volt ones.
What kind of EMP are you interested in building? What kind of specs?
The monitor i believe was an Azura, some cheap knock off brand.
I got the capacitors from the... Chip from the inside, I am not sure what it is called.
Well, the type of Emp I am trying to build is just a small radius emp, nothing bigger than... well Something small, because i don't want to knock out a city block or i'll be screwed.
The specs, well i don't know, a bunch of capacitors and what ever else i need... that doesn't contain explosives, even tho i know how to make them. I just rather not blow off a few fingers. I am not that carefull.
*Im going to go check on the monitor.*
It's an Azura 14 A+.
anyways, i want to build an EMP *not to be repetative*
something that doesn't do that far distance, something less than 30 yards, or something like that... SOMETHING SMALL :P.
something made with easy components, readily available components.
thank you
XSNIDALX :eek:
The closest thing I can think of to an "EMP" would be a Tesla coil. This would produce high voltage RF fields. A small one would be reasonably safe, as long as you kept it away from your computers or sensitive electronics.
However, your capacitors would be too low voltage for the components needed for a Tesla coil (and of course the main component of the Tesla coil is the coil itself, though it does use capacitors too, and some sort of switching device such as a spark gap).
I suppose you could try and build a really low voltage version of a tesla coil with only a 200v primary, and some sort of relay for a switch, with the parts you have.
There's more on Tesla coils at
http://users.tm.net/lapointe/TeslaMain.htm
Be very careful. You are working with lethal voltages and currents.
An EMP is just that, a large electromagnetic pulse. What you are doing
is shorting out charged capacitors which release a very large power
(modest energy, short time). If you want a true EMP that will take down
your city's power grid, you need a LOT of energy, much more than you will
ever store in a capacitor from a monitor.
Now just because you short it out does not mean you are radiating a
large portion of the power. To do that you want to short it out through
a large loop of wire. This is basically a scaled up version of Hertz's
original radio experiments. Look up "spark-gap transmitter - Hertz" and
you get all the data you need.
YOU ARE WORKING WITH LETHAL VOLTAGES AND CURRENTS
Never forget that, and always keep one hand in your pocket when the
cap is charged.
1. How does an EMP work?
An EMP, or electromagnetic pulse, works by releasing a strong burst of electromagnetic energy that can disrupt or damage electronic equipment. This can be achieved through various methods, such as using explosives or high-power microwave devices.
2. Is it possible to build an EMP without using explosives?
Yes, it is possible to build an EMP without using explosives. This can be done by using capacitors, which store and release electrical energy, to create a strong electromagnetic pulse.
3. What materials are needed to build an EMP using capacitors?
The materials needed to build an EMP using capacitors include high voltage capacitors, a high voltage power supply, a spark gap, and various other electronic components such as resistors and diodes.
4. Is it difficult to build an EMP using capacitors?
Building an EMP using capacitors can be a complicated process and should only be attempted by those with a strong understanding of electronics and the necessary safety precautions. It is important to follow a step-by-step guide and take necessary precautions to avoid harm to yourself or others.
5. What are some potential applications of an EMP?
An EMP can be used for a variety of purposes, such as in military operations for disabling enemy electronic equipment, in research and testing of electronic equipment's vulnerability to EMPs, and in some cases, for emergency situations such as disabling a vehicle's electronic locks in the event of a carjacking.
  • DIY Projects
  • DIY Projects
  • Electromagnetism
11K
  • Electrical Engineering
  • General Engineering
