Endothermic Paint: Absorbing Heat and Keeping Cool
In summary, a new type of paint has been developed that contains small glass beads and acts as insulation when applied to walls. It is described as being endothermic in nature, meaning it absorbs energy from the outside system. However, it is already dried so it is unclear where the energy is going. The paint was developed in cooperation with NASA and is used for solar heating and refrigeration. It is also noted that a black paint or color can affect the rate of heat loss in objects.
dnorric
Ok so there's this paint that has been produced which contains small glass beads. When painted on to a wall it acts as insulation. Very good insulation in fact. I was listening to a radio show where a person was talking about it and he described that it was endothermic in nature. Now i know what endothermic is. In a chemical reaction energy is absorbed from the outside system. In this case something is being done, that is a reaction. How ever with the paint it is already dried. They describe the paint as being cool to the touch out in the dessert. If its endothermic, where is the energy going? Whats it doing work on?
Cheers
Damian
They almost certainly didn't mean endothermic.
And it will only act as an insulator in that it reflects sunlight - paint is too thin to be an efficient insulator.
Thanks mgb_phys. The paint has tiny glass spheres added to it and was developed in cooperation with nasa. Heres a link
http://www.thermilate.com.au/
Yeah that's what i thought. I am sure he said endothermic though, have to relisten.
Cheers
Damian
Chrome engines look nice at car shows, but you don't see much chrome at the dragstrip. Chrome reflects heat internally resulting in a hotter running engine.
The reverse is also true, most high performance, high compression motorcycle engines are black, aestetics is not the only reason for this. Ever notice most water cooled engine radiators are black in color?
Solar heating devices and refridgeration equipment use color and "paint" to their advantage as well.
Two identical metalic objects, one painted metalized silver(white may work as well, or better in some instances), the other flat black, heated in an oven. Typically, when taken out, the flat black object will lose heat more quickly. Yes there are many variables, but I have done this experiment with two quarters, taken to 400 degrees Fahrenheit.
What is endothermic paint?
Endothermic paint is a type of paint that is designed to absorb heat from the environment, making the surface it is applied to feel cooler.
How does endothermic paint work?
Endothermic paint contains special pigments and additives that are able to absorb heat from the sun or other sources. This absorption process causes the paint to feel cooler to the touch.
What are the benefits of using endothermic paint?
The main benefit of endothermic paint is that it can help to keep surfaces and buildings cooler, reducing the need for air conditioning and saving energy. It can also help to extend the life of the surface by reducing heat-related damage.
Can endothermic paint be used on any surface?
Endothermic paint can be used on a variety of surfaces, such as roofs, walls, and even vehicles. However, it is important to check the manufacturer's instructions and ensure that the surface is suitable for the paint before application.
Is endothermic paint safe for the environment?
Most endothermic paints are safe for the environment as they do not contain harmful chemicals. However, it is always important to check the ingredients and choose a paint that is labeled as environmentally friendly.
  • DIY Projects
  • Other Physics Topics
