Homework Help: Energy and force question
  1. Apr 23, 2015 #1
    An archer pulls a bowstring back 0.440 m, and the spring constant of the bow is 545 N/m. Find the amount of work the archer did to draw the bow.
    2. Relevant equations
    F = ma
    Ei = Ef
    3. The attempt at a solution
    It seems as though there are two ways of doing this: using Newton's laws or using conservation of energy.
    a) Newton's laws:
    W = Fd
    F = -kx = 240 N
    d = 0.440 m
    W = Fd = 106 J
    b) Conservation of energy
    Ei = Ef
    Wapply = Ufinal
    Wapply = (1/2)kx2 = 53 J
    As one can see, these are two different answers. In fact, the latter is exactly half of the former. What am I doing wrong? Is either answer even right?
  3. Apr 23, 2015 #2
    Doc Al
    Staff: Mentor
    This is incorrect. This calculation assumes the force is constant, but it's not: it varies from 0 to the maximum value.
    This is correct.
    If you find the work correctly, by integrating ##\int F dx## since F is not constant, you'll get the same answer as you did in (b).
    (Since the force varies linearly, you can cheat a bit and use the average force times the distance. The average force is 1/2 of the max force, so that will also give you the correct answer.)
  4. Apr 23, 2015 #3
    Was just writing pretty much what Doc Al said. You'll also notice that in your first method, W = Fd = Fx = -kx^2 ...twice your second answer.
Have something to add?
Draft saved Draft deleted
