Energy bike problem
  • Thread starter jefgreen
jefgreen
78
1). Shawn and his bike have a total mass of 45.0kg. Shawn rides his bike 1.80km in 10.0 min at a constant velocity. What is Shawn's kinetic energy?
m=45.0kg (Shawn+Bike total mass)
t=10.0min-->600sec
d=1.80km-->1,800m
K=1/2mv^2.
so...K=1/2(45.0kg)(???)^2
I'm assuming v=3m/s
Therefore v=3.0m/s?
Answers and Replies
Filip Larsen
507
Almost got it. You got speed from distance and time (no need to assume 3 m/s, calculate it!), and then you insert this speed into the equation for kinetic energy you correctly quoted.
If you are confused about why the kinetic energy can be constant with Shawn pedalling along, you may want to think about where all the energy his muscles release end up when its not going into increasing his speed (hint: what happens if he stops pedalling and why does that happen).
jefgreen
78
So, did I complete the problem correctly?
Filip Larsen
507
You didn't give any final answer. The question is what Shawns kinetic energy is, that is, the value of the formula for K you gave. In your post you inserted the mass in this formula but did not insert the speed. Insert that and calculate the result and you have your answer (which should also include a correct physical unit for energy).
jefgreen
78
Thank you. And the unit for energy is Joule (J).
jefgreen
78
Is the answer 202.5J correct?
Filip Larsen
507
Yes, that is correct.
Suggested for: Energy bike problem
  • Last Post
  • Last Post
