1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Energy Conservation Problem
  1. Oct 27, 2007 #1
    This is Problem 10.46 from the Engineering Physics Book by Knight.
    A vertical spring with k = 490 N/m is standing on the ground. You are holding a 5.0 kg block just above the spring, not quite touching it.
    a.) How far does the spring compress if you let go of the block suddenly?
    b.) How far does the spring compress if you slowly lower the block to the point where you can remove your hand without disturbing it?
    I have missed class 3 days in a row (sick) and do not know what to do at all. That being said, thorough answers are appreciated.
  3. Oct 27, 2007 #2
    rl.bhat
    Fall of potential energy of the block=energy stored in the spring. Assume block moves x m. The block moves the same distance whether you release the block suddenly or slowly.
  4. Oct 27, 2007 #3
    Shooting Star
    a.) You have to equate the initial and final energies.
    b.) You have to equate the weight of the body to the upward force by the spring. In the 2nd case, you are not allowing the mass to transfer all its PE to KE.
  5. Oct 27, 2007 #4
    Shooting Star
    That is not correct.
  6. Oct 28, 2007 #5
    Here you must consider that the potential energy of the block gets converted to the elastic potential energy of the spring. Which lets say gets compressed by x meters.
    Hence
    [tex] \frac{kx^2}{2} = mgx [/tex]
    Here in case of the right hand equation we will consider only x as the block is left from almost negligible height.
  7. Oct 28, 2007 #6
    Shooting Star
    Does this cover both the cases, according to you? What about the fact that I am lowering the mass in the 2nd case by holding it in my hand?
  8. Oct 28, 2007 #7
    rl.bhat
    Spring problem
    When I said fall of potential, I ment that the block is moved in the down ward direction.
    In the 2nd part you are removing the hand when the block remains indisturbed. And it is the position of the maximum compression of the spring. And it is the same wherher you remove the hand suddenly or slowly.
  9. Oct 28, 2007 #8
    Shooting Star
    Please read my earlier post. The answers to the two questions asked by the OP are different.
    In case b, the block on the spring will stay at some point, when equilibrium is achieved.
    In case a, the spring is compressed beyond that point and then again bounces up. Without friction or dissipation of energy, it will continue to oscillate, with the position in case a as the mean position.
    Let the OP give us the final values.
Similar Discussions: Energy Conservation Problem
Loading...
