Energy conservation problem
In summary, the given problem involves a 2.0 kg block on a frictionless 30° incline with a compressed spring of force constant 19.6 N/cm. The spring is compressed by 20 cm and then released, causing the block to move up the incline. The question is asking for the distance the block will go before coming to rest. One suggested solution is to calculate the potential energy stored in the spring and equate it to the change in gravitational potential energy. However, there are concerns about this approach due to the assumption that the spring will be at its equilibrium position when the block reaches its highest point. Another solution is to calculate the work done by the spring on the block and equate it to the
Syrus
214
Consider the following situation:
A 2.0 kg block is placed against a compressed spring on a frictionless 30° incline. The spring
of force constant 19.6 N/cm is compressed 20 cm and then released. How far up the incline will the block go before coming to rest?
The suggested (but perhaps naive) solution to this problem is to calculate the potential energy stored in the spring when it is compressed and set this value equal to the change in gravitational potential energy (see, for instance, http://www.physics.udel.edu/~jim/PHYS207_10J/Homework%20Solutions/Hwk7sol.pdf ). However, I see two fundamental problems with this approach:
First, suppose our system is composed of the block, spring, ramp, and Earth. Then at its highest point (as with its initial condition when it compresses the spring), the block has no kinetic energy. Let the release point be the reference point for gravitational potential energy (potential energy = 0) and the unstretched equilibrium length of the spring to be its potential energy reference point. What is to say that when the block reaches its highest point, the spring will be at its equilibrium position? If this is not the case, then it certainly can't be true that the entire spring potential energy may be converted to gravitational potential energy. What I see the problem to be is attributing the potential energy stored in the spring to the energy transferred to the ball. Is this not a problem, in general?
This problem is from an elementary text and, as such, may not be written paying attention to such details. Nonetheless, I have devised a solution which is independent of the abovementioned approach, but still poses some questions:
We may calculate the work done by the spring on the box as it is released (since we are given the force constant and initial compression of the spring) and set this value equal to the change in gravitational potential energy (in this case we take only the box, ramp, and Earth as our system). This equation holds since here an external force acts on our system. This approach also yields the *suggested solution. However, it doesn't seem obviously true that the spring stops acting (contacting) on the box as it passes through its equilibrium position (which is an underlying assumption of this method)?
Any advice?
I think your initial approach is right. Apply conservation of energy...The block continues up until the PE stored in the spring has all been converted to potential energy in the block.
I think the problem is that simple but you are right that in the real world it might not be quite like that..
Why does that matter? The block is not fixed to the spring just placed against it. Once the spring reaches it's rest position it's delivered all it's PE to the block.
In the real world the spring has mass and the end of the spring will have velocity and KE as it reaches and passes the rest point. In other words not all the PE ends up in the block. The question doesn't state that the spring is mass less but the mass isn't given so you can worry about that sort of thing. A massless spring can do things like stop instantly :-)
Ah, so the fundamental, simplifying assumption is that the spring instantly come to rest upon reaching its equilbrium length. Perhaps this should be stated in the problem, no?
As a scientist, it is important to approach problems with a critical and analytical mindset. In this case, there are indeed some potential issues with the suggested solution.
Firstly, as stated, assuming that the spring will be at its equilibrium position when the block reaches its highest point is not necessarily valid. This is because the block may have some kinetic energy due to its motion along the incline, which would affect the position of the spring. Additionally, there may be external forces acting on the system, such as air resistance, which could also affect the position of the spring.
Secondly, the assumption that the spring stops acting on the block as it passes through its equilibrium position may not be true. In reality, the spring may continue to exert a force on the block as it moves up the incline, even if the force decreases as the spring stretches. This could affect the accuracy of the calculated solution.
In order to address these issues, a more comprehensive analysis of the system is necessary. This could involve taking into account the kinetic energy of the block, the effects of external forces, and the behavior of the spring as it stretches and releases its energy. By considering all of these factors, a more accurate solution can be obtained.
In general, when approaching energy conservation problems, it is important to carefully consider all the variables and assumptions involved in the problem. While the suggested solution may provide a reasonable approximation, it is always important to critically evaluate the approach and consider alternative methods to ensure the accuracy of the solution.
1. What is energy conservation problem?
The energy conservation problem refers to the issue of decreasing energy resources and increasing energy consumption. This leads to a significant impact on the environment and climate change.
2. Why is energy conservation important?
Energy conservation is important because it helps reduce our dependence on non-renewable energy sources, which are finite and contribute to pollution and climate change. It also helps save money on energy costs and promotes sustainable living.
3. What are some ways to conserve energy?
There are several ways to conserve energy, including turning off lights and electronics when not in use, using energy-efficient appliances, insulating homes and buildings, carpooling or using public transportation, and using renewable energy sources.
4. How does energy conservation benefit the environment?
Energy conservation benefits the environment by reducing carbon emissions and pollution, which contribute to climate change and air and water pollution. It also helps preserve natural resources and habitats that are affected by the extraction of non-renewable energy sources.
5. What are the challenges of implementing energy conservation?
Some challenges of implementing energy conservation include initial costs for implementing energy-efficient measures, lack of awareness and education about energy conservation, and resistance to change. Additionally, there may be political and economic barriers to implementing policies and regulations that promote energy conservation.
