What Happens to the Missing Energy in a Closed Circuit with Capacitors?
In summary: When the charges move from one capacitor to the other, they have to accelerate, and accelerating charges emit electromagnetic waves, which carry off energy. That's the primary mechanism the system will use to get rid of the energy in cases where R becomes negligible.
jaumzaum
434
33
Hi everyone,
I was studying eletrodynamics and I've found the the following question
In ideal circuit of the figure, initially opened, the capacitor of capacitance CX is initially loaded and stores a eletric potencial energy E. The capacitor of capacitance CY = 2CX is initially uncharged. After closing the circuit and get it to reach a new equilibrium, you can say that the sum of the energies stored in the 2 capacitors is :
a) 0
b) E/9
c) E/3
d) 4E/9
e) E
[PLAIN]http://img571.imageshack.us/img571/1196/imagemdnf.jpg
The resolution is like that:
Initially the charge stored in capacitor Cx is Q, and the energy is E = Q²/2Cx
When the circuitis closed, after reached the new equilibrum, the tension U in Cx and Cy are the same:
Ux = Uy -> Qx/Cx = Qy/Cy -> Qy = 2Qx
For the conservation of charges:
Qx + Qy = Q
We get Qx = Q/3 and Qy = 2Q/3
So the energy stored after reached the equilibrum is:
Ex + Ey = (Q/3)²/2Cx + (2Q/3)²/4Cx = Q²/6Cx = E/3
My question is:
For the law of energy conservation, the energy can't be created or destroyed, only transformed.
If we consider the resistor R hasn't done anything (we can also take it out that the result'd be the same). Where's the other 2/3 of E?
Why do you think the resistor hasn't done anything?
I assume 2 reasons:
First we don't use it in our resolution (so it makes no sense for it to be there)
Second if the resistor is taken out of the circuit, wouldn't the answer be the same?
You have to consider what happens between the time t=0 and when the circuit finally reaches equilibrium. When the charge moves from the first capacitor to the second, there's a current, and a current through the resistor will dissipate energy.
Of course, this doesn't explain your second question. In a practical sense, you can say that every wire will have some non-zero resistance, so saying R=0 is simply unrealistic. There are also other effects, which you can usually neglect in basic circuits; however, when R becomes very small, these effects become important. For example, the circuit forms a loop, which has an inductance, which will limit how the current flows and will cause the circuit to oscillate. (The inductance is always there, so you might wonder why the circuit doesn't always oscillate. It's because when R is relatively large, the oscillator is overdamped.) The important thing is when the charges move from one capacitor to the other, they have to accelerate, and accelerating charges emit electromagnetic waves, which carry off energy. That's the primary mechanism the system will use to get rid of the energy in cases where R becomes negligible.
Sorry, not sure I understand "resolution". Whether or not it makes any sense for the resistor to be there is irrelevant-- it is part of the circuit in the given problem.
No, you would get 2 different answers.
1. What is a closed circuit?
A closed circuit is a complete loop or pathway that allows electricity to flow from a power source to a load and back again. This means that the circuit is not open or broken, and the flow of electricity is continuous.
2. How does energy flow in a closed circuit?
In a closed circuit, energy flows from the power source, such as a battery or generator, through the conductive material, such as wires, to the load, which is the device that uses the electricity. The energy then returns to the power source, completing the circuit.
3. What factors affect the energy flow in a closed circuit?
The amount of energy that flows in a closed circuit is affected by several factors, including the voltage of the power source, the resistance of the conductive material, and the type of load. Higher voltage and lower resistance will result in a greater flow of energy.
4. What is the role of a switch in a closed circuit?
A switch is used to control the flow of energy in a closed circuit. When the switch is open, the circuit is broken and no energy can flow. When the switch is closed, the circuit is complete and energy can flow from the power source to the load.
5. How is energy conserved in a closed circuit?
In a closed circuit, energy is conserved because it is neither created nor destroyed. The energy that flows from the power source to the load is then returned to the power source, completing the circuit. This means that the total amount of energy in the circuit remains constant.
