Allen_Wolf
- 48
- 4
What happens to the energy that goes inside a black hole. Will it stay there or get converted into some other forms of energy. What will happen to it?
It becomes added to the mass of the black hole.Allen_Wolf said:What happens to the energy that goes inside a black hole. Will it stay there or get converted into some other forms of energy. What will happen to it?
So won't the mass be balanced by the antiparticles?newjerseyrunner said:It get's stuck, that's the point of a black hole, anything that gets sucked down into it never comes out.
That was the short answer. The more complex answer is that it's energy will constantly create particle/antiparticle pairs (like everything else) which will almost instantly destroy each other. Every once in a while though, those particles are created in exactly the right point beyond the event horizon that one of them escapes. This is called Hawking Radiation, and it will eventually cause all black holes to evaporate. The largest black holes (which evaporate most slowly) will finally pop out of existence in around 10^100 years.
No. Anti-particles have positive mass, just like particles.Allen_Wolf said:So won't the mass be balanced by the antiparticles?
Allen_Wolf said:won't the mass be balanced by the antiparticles?
Chalnoth said:Anti-particles have positive mass, just like particles.
Sir I'm still a bit confused.No. Anti-particles have positive mass, just like particles.
Thank you SIrPeterDonis said:No. In the heuristic model of Hawking radiation that newjerseyrunner described, the antiparticle that falls into the hole (while its particle partner escapes) has negative energy, so "adding" it to the hole's mass results in a slightly reduced mass for the hole. Note that this is a heuristic model and has many limitations.
Not in the particular case newjerseyrunner was describing--see above. But one of the obvious limitations of this heuristic is trying to explain how a particle or antiparticle can have negative energy--you end up having to unpack "negative energy" into something that doesn't really justify that ordinary language phrase.
Yes, in such extremes of the universe, it's important to remember that matter is sort of like congealed energy, and when talking about gravity, energy and mass are the same and interchangeable.Allen_Wolf said:So will light energy also get added to the mass of the black hole?
Allen_Wolf said:The particles that go into the black hole also has +ve mass right?
thank you sirnewjerseyrunner said:You'll kick yourself when you realize why, it's nothing special or tricky, just geometry.
If only one of the particles gets kicked out and the other falls back into the hole, that means that they had different gravitational potentials. Therefore the one created further from the black hole must have more energy than the one below it. Since the creation of the pair can basically be described as them borrowing energy from spacetime, that energy debt has to be repaid, normally it happens through recombination, this time, it has to end up as a net loss of energy for the black hole.
Allen_Wolf said:Why and how does only the +ve matter escape ?
newjerseyrunner said:If only one of the particles gets kicked out and the other falls back into the hole, that means that they had different gravitational potentials.
Thank you for the correctionPeterDonis said:No, it doesn't. This is an incorrect extension of the heuristic model. Gravitational potential has nothing to do with the process of Hawking radiation. You can model the process, at this heuristic level, with both particles being created at exactly the same altitude above the horizon, and therefore at exactly the same gravitational potential; so it can't possibly be a difference in potential that makes one fall into the hole and the other escape.
Interesting, so what causes one particle to fall in and the other to be ejected? Are they created identically then quantum fluctuations separate them or something?PeterDonis said:No, it doesn't. This is an incorrect extension of the heuristic model. Gravitational potential has nothing to do with the process of Hawking radiation. You can model the process, at this heuristic level, with both particles being created at exactly the same altitude above the horizon, and therefore at exactly the same gravitational potential; so it can't possibly be a difference in potential that makes one fall into the hole and the other escape.
newjerseyrunner said:Are they created identically then quantum fluctuations separate them or something?
Oh, that's Hawking Radiation? All this time I was wondering, that anything (this 'radiation) can escape black hole.newjerseyrunner said:...The more complex answer is that it's energy will constantly create particle/antiparticle pairs (like everything else) which will almost instantly destroy each other. Every once in a while though, those particles are created in exactly the right point beyond the event horizon that one of them escapes. This is called Hawking Radiation, and it will eventually cause all black holes to evaporate. The largest black holes (which evaporate most slowly) will finally pop out of existence in around 10^100 years.
Black holes are not special, and particle pair production is not a properly of them. It seems to be a property of spacetime itself, it happens all the time, everywhere.Stephanus said:Oh, that's Hawking Radiation? All this time I was wondering, that anything (this 'radiation) can escape black hole.
So this particle created just outside event horizon.
What particle is it?
Even in the event horizon it takes near the speed of light to escape black hole, so there's a chance that the particle gets attracted into the black hole instead of escaping?
Now about its speed. Once this particle is created it has already tremendous speed?
And last question.
Perhaps this is off topic.
There are particles/anti particles created near the event horizon, why?
Why is energy converted near EH?
Does it happen in our everyday life? Not in MRI machine I mean.
I mean in our stove, refrigerator, does particle/antiparticle pair is created from energy in our everyday life?
And if it's not, just like my question above, why black hole creates particle/anti particle?
Thank you very much.
Do you mean that everytime, anywhere not just in MRI machine, electron/positron production can happen? In my kitchen for example?newjerseyrunner said:Black holes are not special, and particle pair production is not a properly of them. It seems to be a property of spacetime itself, it happens all the time, everywhere.
I'm pretty sure that the particle itself is either an electron or a positron.
newjerseyrunner said:I'm pretty sure that the particle itself is either an electron or a positron.
Stephanus said:Do you mean that everytime, anywhere not just in MRI machine, electron/positron production can happen? In my kitchen for example?
Sorry PeterDonis, so you're saying that everytime anywhere (I don't know the rate) there are particle/anti particle created?PeterDonis said:...Not only can it happen, it is happening--at least, it is if you interpret "vacuum fluctuations" as virtual particles. But that interpretation has significant limitations.
Stephanus said:so you're saying that everytime anywhere (I don't know the rate) there are particle/anti particle created?
So in this case of Hawking Radiation, there are particle/antiparticle paris that are created right at the Event Horizon, and the other gets propelled away from black hole, and the other gets sucked into black hole?PeterDonis said:...Also, under this interpretation, the particle/antiparticle pairs that are continually being created everywhere annihilate each other right after...
Stephanus said:in this case of Hawking Radiation, there are particle/antiparticle paris that are created right at the Event Horizon, and the other gets propelled away from black hole, and the other gets sucked into black hole?
Stephanus said:what about the "get away" speed? Is it near the speed of light?
Thank youStephanus said:So in this case of Hawking Radiation, there are particle/antiparticle paris that are created right at the Event Horizon? , and the other gets propelled away from black hole, and the other gets sucked into black hole?PeterDonis said:In a particular heuristic picture of Hawking radiation, yes. But, as I've said, this heuristic picture has significant limitations.
Thank youStephanus said:And what about the "get away" speed? Is it near the speed of light?PeterDonis said:In that particular heuristic picture, yes, the particle that flies away from the hole is moving at nearly the speed of light, relative to observers that are "hovering" near the hole's horizon. But, once more, this heuristic picture has significant limitations.
A black hole is a region in space where the gravitational pull is so strong that nothing, including light, can escape from it.
Energy inside a black hole is created through the immense gravitational pull of matter collapsing in on itself. As matter falls into the black hole, it gains kinetic energy, which is then converted into heat and radiation.
No, we cannot see the energy inside a black hole as it is trapped inside the event horizon, which is the point of no return for anything that enters the black hole. However, we can observe the effects of this energy on the surrounding matter and space.
The energy inside a black hole is thought to eventually be converted into mass, which contributes to the overall mass of the black hole. This process is known as Hawking radiation and is still being studied and debated among scientists.
Currently, we do not have the technology or knowledge to harness the energy inside a black hole. The immense gravitational forces and extreme conditions inside a black hole make it impossible for humans to physically access or manipulate the energy inside.
