Why is the Energy Level Higher on the P Side of a PN Junction Diode?
In summary, the energy level is higher on the p-side of a pn junction diode compared to the n-side. This is due to the difference in Fermi levels, which was explained earlier in the lectures on the pn junction. The article provided a hint for this question, but if it is insufficient, it is likely that the author has already covered it in previous lectures.
physics.cie
Why energy level is higher on p side of pn junction diode as compare to n side of same
Oh no. The justification given in link is not complete. Read it again
This is your research project! The article explains the pn junction quite well, and provides a _hint_ for your question in case you have forgotten.
Hint: if the hint given was insufficient for recall, then you can assume that the author has explained it earlier in his lectures ... probably when explaining Fermi levels.
Ok. I will read . Thank you
What is a pn junction?
A pn junction is a type of semiconductor junction formed by bringing together a p-type semiconductor (having positively charged carriers) and an n-type semiconductor (having negatively charged carriers). This junction creates a depletion region at the interface where electrons and holes recombine, resulting in a potential barrier.
How does the energy level in a pn junction affect its behavior?
The energy level in a pn junction determines the direction and magnitude of the flow of charge carriers. In an equilibrium state, the energy levels are balanced, resulting in no net flow of charge. However, when a voltage is applied, the energy levels become imbalanced, allowing for the movement of charge carriers across the junction.
What is the band gap in a pn junction?
The band gap in a pn junction is the difference in energy levels between the conduction band (where electrons can move freely) and the valence band (where electrons are bound to atoms). This band gap is responsible for the creation of the depletion region and the potential barrier in a pn junction.
How does the doping level affect the energy level in a pn junction?
The doping level (concentration of impurity atoms) in a pn junction determines the width and intensity of the depletion region. Higher doping levels result in a thinner depletion region and a lower potential barrier. Lower doping levels result in a wider depletion region and a higher potential barrier.
What is the difference between forward and reverse bias in a pn junction?
In forward bias, the applied voltage is in the direction of the potential barrier, allowing for the movement of charge carriers across the junction. In reverse bias, the applied voltage is in the opposite direction of the potential barrier, preventing the movement of charge carriers and resulting in a wider depletion region.
  • Atomic and Condensed Matter
  • Classical Physics
  • Electrical Engineering
