Energy levels of partciles in a 3D box
In summary: The lowest energy state is (1, 1, 1) and two electrons can fit here because of spin degeneracy. The next highest energy is (2, 1, 1), (1, 2, 1), and (1, 1, 2), with two electrons in each state. Continue in this way to place the last two electrons, but be careful to make sure that it is really the next level and not a higher one.
emilykay
Energy levels of a particle in cubic box with sides length a are:
E= [(h^2 pi^2)/(2 m a^2)] * (nx^2 + ny^2 + nz^2)
where nx, ny, nz are integers 0.
If 10 electrons are placed in this box, what is the lowest possible total energy of all the electron?
I am finding this question really intersting but I am stuck over one thing..
Why does it say "where nx, ny, nz are integers 0"
Surley this means that only 2 electrons can fit in the box, one spin up, one spin down?
I don't understand! please help...
Does is specifically say "where nx, ny, nz are integers 0" or is it some mathematical symbol that you have converted into words? (say, [itex] n_x, n_y, n_z \in \mathbb{Z} - \{0\} [/itex])
It says "where nx, ny and nz are integers 0."
i think [tex]n_x=n_y=n_z=0[/tex] does mean, that all the electrons are in the ground state and as we know from Pauli's exclusion principle electrons (fermions) can only once occupy a quantum state which is specified by n and [tex]spin=\pm\frac{1}{2}[/tex]. So as you noticed emilykay only 2 electrons can fit in the box, one spin up, one spin down
Okay, thanks for your help!
It seems a bit strange though how this question is kindof a trick question seeing as its asking about 10 electrons. and its worth 6 marks so i don't know how it can be a trick...
Does anyone else know?
Emily.
Hootenanny said:
Zero is not an integer.
you are right. the ground state energy is for n=1. maybe it should be [tex]n_x, n_y, n_z \not=0[/tex]. so you should try all combinations and find the lowest possible energy
It is...
zero is an integer,
The lowest energy is (nx,ny,nz)=(0,0,0)
Yes, you are right, sorry my bad.
then you have to start at 0
thanks for your help. Definitly think its an error as the sentance doesn't really make sense.
I think it should read "where nx, ny, nz are integers not equal to zero". Consider the one-dimensional case. If n=0 then [itex]\psi[/itex]=0 everywhere, and so the particle is not in the box. This can then be generalised to the 3D case, and thus ni must be non-zero.
I think the correct sentence is: "where n_x, n_y, n_z are integers not all equall to zero".
Usually you can have zero quanta in two directions for a particle. So what you need to do is to find the configuration of 10 particles that yields the lowest total energy. Remember that you must take into account the Fermi principle.
I would guess that there is a missing greater than sign in the problem, and that all of nx, ny, and nz have to be > 0.
Take a look at, for instance, http://en.wikipedia.org/wiki/Particle_in_a_box
While 0 is an integer, it's does not correspond to a valid solution. This can be deomnstrated by writing the appropriate expression for the wavefunction phi and imposing the boundary condition that phi=0 at the edge of the box.
The anwer to the problem is unique, if electron spin is taken into account. But there are several posibilities to take the triplet ([itex] n_{1},n_{2},n_{3} [/itex]) to get the minimum energy.
Daniel.
It should definitely read greater than 0.
The wavefunction for a three-dimensional particle in a box is just three one-dimensional wavefunctions multiplied together. Thus, a zero for any of the three quantum numbers reduces the total wavefunction to zero. Therefore, the lowest energy state is (1, 1, 1) and two electrons can fit here because of spin degeneracy. The next highest energy is (2, 1, 1), (1, 2, 1), and (1, 1, 2), with two electrons in each state. Continue in this way to place the last two electrons, but be careful to make sure that it is really the next level and not a higher one. E.g., which is lower, (1, 1, 3) or (2, 2, 1)?
1. What is a 3D box in terms of energy levels?
In the context of particle physics, a 3D box refers to a theoretical model where a particle is confined to a three-dimensional space with boundaries. This model is often used to study the energy states of particles.
2. How are the energy levels of particles in a 3D box determined?
The energy levels of particles in a 3D box are determined by solving the Schrödinger equation, which describes the wave function of the particle in the confined space. The solutions to this equation give the allowed energy levels for the particle.
3. Can the energy levels of particles in a 3D box be quantized?
Yes, the energy levels of particles in a 3D box are quantized, meaning they can only take on specific discrete values. This is due to the boundary conditions imposed by the box, which restrict the possible energies of the particle.
4. How does the size of the 3D box affect the energy levels of particles?
The size of the 3D box directly affects the energy levels of particles. As the size of the box decreases, the energy levels become more closely spaced. Conversely, as the size of the box increases, the energy levels become more widely spaced.
5. Are the energy levels of particles in a 3D box the same for all particles?
No, the energy levels of particles in a 3D box are not the same for all particles. The energy levels depend on the mass and charge of the particle, as well as the size of the box and the boundary conditions imposed on it.
  • Quantum Physics
