Energy of a Particle: Rest Mass & Beyond
In summary, the electron has a different energy depending on whether or not it is in the vicinity of other particles.
touqra
287
For a test particle which is all by itself and is at rest, the total energy of the particle is the rest mass.
But what if let say, this test particle is a proton. This proton is at rest and is not in the vicinity of any other particles. It is all by itself. Considering that proton has charge, from QED, we know that this proton will emit virtual photons with certain probability. Would this change the energy of the proton, and hence the rest mass of the proton?
From gravitational force, and that the proton has a mass, the proton will exert a gravitational field that spreads to the whole space. If there is another massive particle nearby, then, there will be an attraction potential energy, and hence, it will change the energy of the proton.
But what if there are no particles nearby? The proton still exerts a field. Will the proton's energy (rest mass) be changed due to its own field?
The physical mass of a particle does include all these self-field effects, and more from strong interactions. Actually, most of the physical mass of the proton results from its three constituent quarks.
This is not quite true. Most of the mass is from the internal motion of the quarks and gluons that make up the proton, not from the quark mass irself.
Thanks. But my question is still unanswered. Perhaps I should not use proton. Maybe I should use electron. There is no known smaller constituents that make an electron, so let's take electron as the smallest entity.
Electrons can produce a gravitational field or produce virtual photons even without the presence of any other particles. So, do these production of fields and photons change the energy of the electron? Like adding a potential energy or the likes.
This is not correct since most of the proton mass comes from the "motion" of virtual quark anti-quark pairs and virtual gluons inside the proton.
Dynamical quarks
marlon
I did not say "from the quark mass itself".
Dynamical quarks
marlon
Now look on your web for "constituent quark".
The first sentence of my first post "The physical mass of a particle does include all these self-field effects," answered for the electron. There is a big shift in the rest energy due to the photons and pairs in a physical electron..
Maybe you want to look at paragraph S3a of http://arnold-neumaier.at/physics-faq.txt
regards
marlon
I think if there are no fields in the vicinity of the electron it these corrections are unimportant. I think the electron self-energy is only relevant when it's interacting with something else
I completely agree with this
marlon
What is the energy of a particle?
The energy of a particle is a measure of its ability to do work or cause changes in the environment. It can exist in different forms, including kinetic energy, potential energy, and rest energy.
What is the rest mass of a particle?
The rest mass of a particle is the mass it possesses when it is at rest, meaning it is not moving or interacting with other particles. It is a fundamental property of a particle and is a measure of its inertia.
How is the energy of a particle related to its rest mass?
The energy of a particle is related to its rest mass through Einstein's famous equation, E=mc^2. This equation shows that the energy of a particle is equal to its rest mass multiplied by the speed of light squared.
Can a particle have energy even if it has no rest mass?
Yes, according to Einstein's equation, even particles with zero rest mass, such as photons, still possess energy. This is because they have momentum and move at the speed of light, which contributes to their energy.
What is the significance of the energy of a particle in physics?
The energy of a particle is a crucial concept in physics, as it is conserved and plays a role in various physical processes. It is also closely related to other fundamental properties of particles, such as momentum and mass.
