Energy of a water 'fan'
  • Thread starter Forlax
Main Question or Discussion Point
How would you go about calculating the energy required to propel water through a circular-type blade at 3 metres per second??
Thanks.
Answers and Replies
79
in this case you would be calculating power (energy per time)
think about how much mass is moving, and how fast it is going.
then use the equation for kinetic energy.
bear in mind, that this is the MINIMUM amount of power required, since it is assumes 100% conversion of propeller work to kinetic energy. The actual number is much greater and difficult to predict.
It is probably only estimable by using correlations based on the reynold's number and propeller design.
russ_watters
Mentor
19,027
5,186
Obviously it depends on the device, but you can figure 50-75% efficiency for a pump or propeller.
Related Threads for: Energy of a water 'fan'
  • Last Post
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
