Exploring the Relationship Between Energy, Potential, and Work
  • Thread starter nouveau_riche
  • Tags
    Energy Work
In summary, energy is the capacity/ability to do work. If the sign of work is the answer, then it is just a matter of convention.
nouveau_riche
253
what is energy?
as much as i know "energy is the capacity/ability to do work"
if that is true then
what is potential ?
how can energy be positive or negative?
if the sign of work is the answer then it is just a matter of convention
You are right, energy is capability to do work. Feynman explained energy like this: there is a child who has a certain number of toy blocks, and he keeps hiding them in different places, but the number of toy blocks always stayed the same.
So a good definition of energy is simply something which is conserved with time. Potential energy are all the forms of energy that are not kinetic energy.
In most situations, the actual value of the energy is not important, only that it doesn't change with time. The actual value of energy might be important in quantum field theories though.. I'm not sure
There are many forms of energy...potential, kinetic, rotational, electrical,magnetic, nuclear,thermal,chemical, etc.
lots here:
http://en.wikipedia.org/wiki/Energy
and note "transformations" from one form of energy to another...
potential energy: see here:
http://en.wikipedia.org/wiki/Potential_energy
and see the "reference level" for positive/negative.
Potential also commonly applies to electrical potential which is another term for voltage.
In cosmology, gravitational energy is usually taken as a negative while nulcear reactions, such as fission and fusion in stars is positive. But that's a convention not an absolute.
And what is work?
Work just means energy transferred from one system to another.
For example, I have chemical energy stored in my muscles. When I throw a bowling ball, I turn some of the chemical energy in my muscles into kinetic energy of the bowling ball. So I would say that I have done work on the ball.
Edit: also, in thermodynamics, work done on a gas usually means the gas is compressed. (Which requires transferring energy from some external source to the gas). In fluids, work can also mean something as simple as stirring the fluid. (Again, energy is transferred from an external system to the fluid, due to its increased kinetic energy).
That would mean energy is capability to transfer energy. Does anybody know a definition of energy or work without such an idem per idem construction?
Yes, there have been many threads on this topic. Just do a search for "what is energy". The threads usually get locked with one or more of the posters being banned.
nouveau_riche said:
what is energy?
what is potential ?
Potential is energy divided by charge.
Only differences in energy are important. So whether you say something has zero energy and falls to -10 J or whether you say that it has 10 J energy and falls to zero the physical result is the same.
How about: 'the energy of a closed system does not change' and 'work done on one system by another is the exchange of energy of those two systems'.
That's not sufficient because it applies not only to energy and work but to all conserved properties and their derivations with respect to time (e.g. momentum and force, angular momentum and torque, charge and current and so on). The definition should be specific for energy and work.
Well, since the OP'er was asking basic questions about energy, I thought I should keep my answers suitable for a beginner in physics rather than go into detail.
If somebody ask me this question I usually give him the same answer. But I don't like it because I know that it is not a valid definition. That's why I am looking for an alternative that is not only handy but correct to.
That's the thing with physics, often you need to sacrifice precise definition so that you can explain something intuitively to someone who is new to the subject.
For example, we are all taught that the electron orbits round the nucleus. But when we learn QM, we find that actually its much more complicated, since the electron doesn't take a particular path through space. And the s-orbital electrons have zero orbital angular momentum, so they're not even moving around the nucleus at all!
But back to energy, I've found (over my time learning physics) that the precise meaning of energy depends on the branch of physics you are using it in.
For lagrangian mechanics, energy is a conserved quantity of the system as long as the potential of the system is not explicitly time-dependant.
In QM, the energy eigenstates are stationary states, meaning that if the entire system is an energy eigenstate, then a change in time only changes the state by a phase factor. (Which is due to the time dependant Schrodinger equation).
Energy/mass in Einstein's relativity is a generalisation of classical energy, such that it is a locally conserved quantity.
Energy in statistics is a useful concept, in that it gives us the distribution of the number of particles in particular energy states.
Energy density in electrodynamics, denoted [itex]u[/itex] is given by the equation:
[tex]\frac{\partial u}{\partial t}=- \nabla \cdot S - J_f \cdot E [/tex]
Application of Noether's theorem says that energy conservation is due to invariance with respect to time translation. So the energy conservation is due to this time symmetry, which is mathematically represented by some kind of group.
This last definition seems like the best and most general definition of energy. Unfortunately, I don't know much about the maths of groups, etc, so I can't tell you exactly what the group is or how it gives rise to a definition of energy conservation..
BruceW: #13 post, very good!
as it appears energy can't be just transfer of energy,a system may have an energy but is not necessarily doing work
well it is not the potential energy or kinetic,i was just only interested in definition of energy
it would be kind of you to provide the best link(the thread)
well no one actually gave me the difference between the energy and potential?
The total energy is the sum of kinetic and potential energies. So if something is a form of energy and is not a kinetic energy, then it is a potential energy.
Edit: So, you could say a particular potential energy (ie gravitational potential energy) is a specific type of energy. Only the total energy is conserved, so we must add up all the types of energy in a system to get the total energy (which is a very useful quantity).
what you brought up here is itself an energy not a potential
as you said it potential energy:smile:
I see, you were asking 'what is potential'? Not 'what is potential energy'. Sorry, I got the two mixed up. Good question.
In physics, there are scalar and vector potentials which are fields in space. So generally, the word 'potential' has nothing to do with energy. But often there are potentials which are related to a form of potential energy.
One example is the (scalar) gravitational potential. If we have a mass in some gravitational field, then the gravitational potential of that field times by the mass is equal to the gravitational potential energy.
Indeed, that's the problem. It seems to be the best compromise to give a simple answer first and if somebody claims that it is not correct to give him your summary of different definitions. Then he will have something to think about :eek:)
Sometimes I start with the definition of mechanical work as the line integral of a force over a path. This also has its limitations but it works for almost all mechanical problems.
Energy is defined as the capacity to do work, as you already stated in your OP. I don't know why you are asking and re-asking a question to which you already know the answer.
I did, in post 8. Frankly, a statement like this is very irritating. If you didn't understand the answer, then ask follow-up questions, but to pretend like nobody answered is rude and makes me less interested in trying to answer further. Why should we bother if you are not even going to read the answers and will pretend that no answer was given.
in spite of the fact that i already know the answer i raise this thread to highlight the similarities between energy and potential,when you talk about potential energy or potential difference you are only taking in account the transformation in energy not the ability to give that energy
hello,
some interactive animations that speak of energy http://physiquecollege.free.fr/physics_chemistry_middle_high_secondary_grammar_school_higher_education_academy_co.uk.us.en/mechanics_interactive.htm" .
"energy is the capacity to do the work" that's correct.. and the word POTENTIAL ENERGY means this has a capacity to do work STILL.. i mean the potential energy is the energy in static state.. all other forms of energies get converted from one to the other in no time.. like kinetic energy of electrons to light energy, light energy to heat energy, and this heat energy to radiations and this further hits a surface and converts to kinetic energy of electrons through the photoelectric effect and so on... But the POTENTIAL ENERGY is one which still has potential to do work and waiting for a chance to do work...
and the signs of energy are just conventions which shows the direction of flow of energy towards or outwards a system or with respect to a system..
The sign is not for the magnitude of the energy...
all the magnitudes of physical quantities are relative to something.. so if the value is zero joules, it doesn't mean it doesn't contain any energy...
Clearly potential and potential energy are similar. They are proportional to each other, by a factor of charge.
What do you mean by this?
in that case potential=energy*k
k being some constant of proportionality and that's all i was interested in
in simple way-what gives charge the energy contained in its potential energy as you like to say it?
  • #31
I wouldn't say that the potential energy is in the charge, I would say that it is in the system. Then what gives the system the energy is the configuration of the different parts of the system.
  • #32
so how would justify that configuration for a particle say electron?
  • #33
An electron, by itself, doesn't have a potential energy.
  • #34
but have the potential to give potential energy
so how does electron gets this potential?
  • #35
Its all about the system man. For example - if we had two massive bodies, then the gravitational potential energy is a property of the system. It isn't a property of one body or the other.
If we had an electron in some external electromagnetic field, then the potential energy is dependant on both the electromagnetic field and the electron.
Another way of thinking is like this: a charged particle gains some kinetic energy. So this energy must have come from somewhere. We realize that it came from the potential energy of the system.
  • Mechanics
