Energy Recuperation Advantages
  • Thread starter bhaazee
  • Tags
    Energy
In summary: High efficiency electric motors also need to be run at much lower speeds than gasoline engines. This limits their usefulness in high-performance sports cars. Finally, electric cars still need gasoline to recharge the batteries, which limits their usefulness as primary transportation. In summary, the main advantages of energy recuperation in vehicles include optimization of fuel consumption, lower CO2 and NOx emissions, and the ability to use electric-only to accelerate the vehicle.
bhaazee
80
Well, the basic advantages of energy recuperation in vehicles include
  1. optimization of fuel consumption
  2. lower CO2 and NOx emissions
Are there any other advantages that needs to be highlighted? Also, please mention the disadvantages of energy recuperation (if any)
Regards
Advantages:
  • better efficiency in stop-and-go traffic. That's what they are designed for, after all.
  • Quieter in electric-only operation. (although some people consider this a danger).
  • Future designs may optimize the ICE for just topping up the batteries and using electric-only to accelerate the vehicle. Train have been running like this for several decades.
  • Hybrid designs may also prepare the way for alternative ways of topping up the battery, e.g. fuel cells.
Disadvantages:
  • Increases vehicle weight.
  • Higher production cost
  • Environmental impact of materials used in e.g. NiMH batteries.
  • Potentially higher maintenance costs.
No advantage if just cruising along without stopping.
Thnx for the reply. However, can only partly agree with your disadvantages. 1, 2, 4 could actually be overcome on long run if utilized properly.
Maybe yes, maybe no. These are disadvantages of the existing designs.
The energy density of fossil fuels is much much higher than any rechargeable battery on the market or under development. This makes big and batteries heavy and is the main stumbling block for all-electrical vehicles.
Hybrids still need to buffer serious amounts of electrical energy. On top of that they need to carry the generator and ICE or other means of generating power.
In present hybrids the ICE still drives the wheels via the usual gear box etc. If the ICE drives only a generator, then one could loose the gear box and one would have much more flexibility in operating the ICE at its maximum efficiency RPM - the speed of the ICE is completely decoupled from the speed of the car/wheels. The weight of the generator is probably comparable to that of the gear box, so not much gained/lost here. One would probably need larger electric motors as all the power accelerating the car will come from them. If 4 motors are put directly on the wheels then no more differentials are needed, saving some weight. Direct traction control of each wheel would be easy, as you can power each motor independently.
Production cost is of course a function of the number of cars sold. On the other hand batteries and high-efficiency electric motors do rely on exotic materials that are expensive.
1. What is energy recuperation and how does it work?
Energy recuperation is the process of recovering and reusing energy that would typically be wasted during certain processes. This can be achieved through various methods such as regenerative braking in vehicles or utilizing waste heat from industrial processes. Essentially, energy recuperation works by capturing and storing energy that would normally be lost and then using it for other purposes.
2. What are the advantages of energy recuperation?
There are several advantages of energy recuperation, including increased efficiency, cost savings, and reduced environmental impact. By recovering and reusing energy, less energy needs to be sourced from non-renewable resources, leading to a decrease in greenhouse gas emissions. Additionally, energy recuperation can save money on energy costs by reducing the need for external sources of energy.
3. How does energy recuperation benefit the environment?
Energy recuperation has several environmental benefits. By reducing the need for non-renewable energy sources, it can help to decrease greenhouse gas emissions and combat climate change. Additionally, by utilizing waste energy, it helps to reduce pollution and waste from industrial processes.
4. Can energy recuperation be used in all industries?
While energy recuperation can be applied to various industries, it may not be feasible or effective for all processes. The applicability of energy recuperation depends on factors such as the type and amount of energy being wasted, the cost and availability of technology, and the specific needs of the industry. However, with advancements in technology, energy recuperation is becoming increasingly accessible and applicable to a wider range of industries.
5. Are there any challenges or limitations of energy recuperation?
Like any technology, energy recuperation also has its limitations and challenges. One major limitation is the high upfront cost of implementing energy recuperation systems, which may make it less feasible for smaller businesses. Additionally, the effectiveness of energy recuperation may vary depending on the specific industry or process, and it may not always result in significant energy savings. Proper maintenance and monitoring are also crucial for ensuring the efficiency and longevity of energy recuperation systems.
  • General Engineering
  • Mechanical Engineering
11K
