No prefix: What is the energy required to ionize air?
  • Thread starter Alex Schaller
  • Tags
    Air Energy
In summary, the conversation discusses the energy required for air ionization and the process involved. Specifically, the conversation touches upon the energy needed to remove a single electron from every atom in a mol of air, and whether or not the charges of ionized air recombine over time. It is suggested that this question may be best answered in a Chemistry forum and that the process for ionization involves breaking molecular bonds and ionizing free atoms. The conversation also references the composition of air (predominantly nitrogen and oxygen) and provides resources for determining the amount of energy needed for ionization.
Alex Schaller
Do you know which is the energy per mol required to ionize air? Once the air is ionized, does it recombine it´s charges so that after a while there is no ionized air at all? If this is the case, how long does it take for this to happen?
Do you mean the VOLTAGE required for air break down? Or the energy required to remove a single electron from every atom in the mol?
I mean the energy required to remove a single electron from every atom in the mol.
I'm not sure whether or not this is homework, but this might be most appropriately answered in the Chemistry forum. Dredging up some of my high school chemistry, the process for ionization requires you to first break the molecular bonds (the triple bonds of nitrogen, and double bonds of oxygen) and form free atoms. Then, you need to ionize them.
Air is composed chiefly of nitrogen and oxygen (total 99%). I'd make a simplifying assumption and assume you have only nitrogen (79%) and oxygen (21%):
http://en.wikipedia.org/wiki/Earth's_atmosphere
Now, assume you have 1 mol of 'air' (0.79 mol of N2 and 0.21 mol of O2), figure out how much energy you need to break the bonds:
http://www.webelements.com/nitrogen/bond_enthalpies.html
http://www.webelements.com/oxygen/bond_enthalpies.html
Now figure out how much energy you need to ionize all these nitrogen and oxygen atoms (how many mols of each?)
http://en.wikipedia.org/wiki/Ionization_energies_of_the_elements
Presto! Amount of energy required to ionize air. Please show your work.
1. What is the definition of "energy required to ionize air"?
The energy required to ionize air is the minimum amount of energy needed to remove an electron from an atom or molecule in air, thus creating a positively charged ion and a free electron.
2. How is the energy required to ionize air measured?
The energy required to ionize air is typically measured in units of electronvolts (eV) or joules (J).
3. What factors affect the energy required to ionize air?
The energy required to ionize air can be affected by factors such as the composition of the air (e.g. the presence of other gases), the temperature and pressure of the air, and the intensity and frequency of the ionizing radiation.
4. Why is the energy required to ionize air important?
The energy required to ionize air is an important concept in atmospheric physics and chemistry, as it plays a role in processes such as lightning formation, the creation of auroras, and the absorption of ultraviolet radiation in the upper atmosphere.
5. How does the energy required to ionize air differ from gas to gas?
The energy required to ionize air can vary from gas to gas due to differences in the atomic or molecular structure of each gas. For example, gases with heavier atoms or molecules may require more energy to ionize, while gases with more loosely bound electrons may require less energy.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Astronomy and Astrophysics
