Energy - running
  1. May 5, 2005 #1
    Hello
    I was trying to calculate the energy in calories used by a man of weight M running at speed V. What would be the fastest way to calculate this?
    E = 1/2 (Vf^2) x M - 1/2 (Vi^2) x M
    (with Vf = final velocity and Vi = initial velocity )
    Oh by the way I designed a simple program for Windows XP about http://www.freewebs.com/horazio/vcl.zip,
    it's very simple but it's also useful for those who study physics. check it out
    http://www.freewebs.com/horazio/freeware.htm [Broken]
  3. May 5, 2005 #2
    dextercioby
    It doesn't make any sense.A man may be running at constant speed (no KE variation),but he'd be burning calories like crazy...
    Daniel.
  4. May 5, 2005 #3
    minger
    Running is very tricky to calculate energy for because it's not perfectly linear. By linear I mean that you don't just travel straight while running. If you think of each running step as a jump at some angle from the horizontal, you can see that there will be a component in the vertical direction. This component would almost certainly depend on the runner and how fast that particular runner was going.
  5. May 5, 2005 #4
    FredGarvin
    If you are going to do it properly, the pros have a way to correlate energy expense as a function of oxygen intake. Since you're not going to do that, you should probably look into work/power instead of energy approach. You probably won't be anywhere in thae ballpark, but it will make more sense than the energy approach.
  6. May 5, 2005 #5
    running (or walking) uses about 50-200 calories per mile depending on your weight, and (to a lesser extent) your speed.
  7. May 5, 2005 #6
    HallsofIvy
    And, in any case, almost all of the calories burned will go "waste" energy because your body is a remarkably inefficient machine.
