I Energy stress tensor of dust
  1. Sep 6, 2016 #1
    If a large cloud of dust of constant ρ is moving with a given ##\vec v ## in some frame, then at any given time and position inside the cloud there should not be no net energy or i-momentum flow on any surface of constant ##x^i ## (i=1,2,3) because the particles coming in cancels those going out off the opposite side of the volume element. So all the spatial ##T^{ij}## components of the energy-stress tensor should be zero. Is my reasoning correct?
  3. Sep 6, 2016 #2
    haushofer
    From the definition of the stressfensor of a dust it is clear that those components vanish for comoving observers. So i'd say your condition is only satisfied by those observers.
  4. Sep 6, 2016 #3
    pervect
    Staff Emeritus
    The stress-energy density of the dust in it's rest frame is
    $$T_{ij} = \begin {bmatrix} \rho & 0 & 0 & 0 \\ 0 & 0 & 0 & 0 \\ 0 & 0 & 0 & 0 \\ 0 & 0 & 0 & 0 \end {bmatrix} $$
    To change frames to one where the dust is moving, we perform a Lorentz boost on ##T_{ij}##
    $$T'_{uv} = T_{ij} \, \Lambda^i{}_u \Lambda^j{}_v$$
    Letting ##\beta = ||v||/c## and ##\gamma = 1/\sqrt{1-\beta^2}## for a Lorentz boost in the ##x^1## direction we can write:
    $$\Lambda = \begin {bmatrix} \gamma & -\beta \gamma & 0 & 0 \\ -\beta \gamma & \gamma & 0 & 0 \\ 0 & 0 & 0 & 0 \\ 0 & 0 & 0 & 0 \end {bmatrix} $$
    So we get that the only nonzero components are
    $$T'_{00} = \Lambda^0{}_0 \, \Lambda^0{}_0 \,T_{00} = \gamma^2 \, \rho \quad T'_{01} = T'_{10} = \Lambda^0{}_0 \, \Lambda^0{}_1 \, T_{00} = -\beta \gamma^2 \rho \quad T'_{11} = \Lambda^0{}_1 \, \Lambda^0{}_1 \, T_{00} = \beta^2 \gamma^2 \rho $$
    i.e.
    $$T'_{ij} = \begin {bmatrix} \gamma^2 \rho & -\beta \gamma^2 \rho & 0 & 0 \\ -\beta \gamma^2 \rho & \beta^2 \gamma^2 \rho & 0 & 0 \\ 0 & 0 & 0 & 0 \\ 0 & 0 & 0 & 0 \end {bmatrix} $$
    So no, all the spatial components of ##T'_{ij}## are not zero, in particular ##T'_{11}## which is what I think you mean by "spatial component"(?) is nonzero in the example where v points in the ##x^1## direction.
  5. Sep 6, 2016 #4
    Okay. Thank you very much. I think that my interpretation of the definition of the stress energy tensor was wrong. I assumed that the flow of α-momentum across a surface of constant ##x^β## meant the net flow of the α-momentum in an element of volume in the β direction. That was an unwarranted assumption, so the reasoning in my original post is invalid.
Have something to add?
Draft saved Draft deleted
