GBA13
- 73
Hi Guys,
I did a heat engine experiment where we put a weight on a piston and moved an air cylinder in a hot water bath, then removed the weight and but the air cylinder in a cold water bath to make a heat engine cycle.
I am just wondering in the simple heat engine which would be larger, The energy transfer from heat reservoir to gas (which I think is the same as the PdV work) or the mechanical work which happens as the piston (with a weight on top) in raised.
I'm also wondering when in an engine cycle is the heat being exhausted to the atmosphere rather than to the cold reservoir?
I think they would actually be the same size. As it is a full cycle then internal energy = 0 so Q14 = W14.
Any help would be appreciated!
Thanks,
Mark
