Entanglement when I "produce" positron-electron pairs one at a time
In summary, entanglement refers to the phenomenon in which particles become connected in a way that their properties are correlated, even when separated by large distances. When producing positron-electron pairs one at a time, these particles may become entangled and exhibit a shared state, meaning that any changes to one particle will affect the other. This has important implications in quantum mechanics and could potentially be used for applications such as quantum computing and teleportation.
  • #36
stevendaryl said:
In the experiment I'm talking about, it's not a two-photon entangled state. The state of the photon is entangled with the state of the electron.
Why then don't you give the details of this experiment or a link to a paper describing it? A quite recent "Schrödinger cat experiment" with atoms and photons can be found here:
https://doi.org/10.1038/s41566-018-0339-5https://arxiv.org/abs/1812.09604
  • #38
vanhees71 said:
You cannot discuss this without defining which experiment is done. Are you talking about the experiment by Dopfer, Zeilinger, et al? Then it's all quite easy to describe by QED, and it's well understood under which setup and for which partial ensembles you see an interference pattern in the single-photon observations or not. To say in the very general "entanglement is relevant to whether interference patterns are seen or not" is an empty phrase.
Here's a description of the sort of thing I'm talking about.
http://www.liceolocarno.ch/Liceo_di_Locarno/Internetutti/ferrari/PDF/vari/MZWW.pdf
  • #39
I am more and more having complaints about the unfriendly tone of Physics Forums discussions. I think I should probably take a long break.
  • #40
stevendaryl said:
Abstractly, we can describe the situation this way:
We have an initial state ##|A, -\rangle##. We have intermediate states ##|C, B\rangle## and ##|F,G\rangle##. We have final states ##|D,B\rangle##, ##|D,G\rangle ##, ##|E,B\rangle ## and ##|E,G\rangle ##. The first component of the composite state is the state of the electron, and the second is the state of the photon (the ##-## in the initial state is because there is no photon in that state).
On the other hand, let's suppose that you erase the information about where the photon came from. The way you can do that is by having some final state ##Z## for the photon which is reachable from both ##B## and ##G##. Letting ##\lambda_{BZ}## be the amplitude for the photon to make a transition from state ##B## to state ##Z## and letting ##\lambda_{GZ}## be the amplitude for the photon to make a transition from state ##G## to state ##Z##, then the amplitude for the composite system to end up in state ##|D,Z\rangle## is:
In this experiment, where the electron state is not entangled with the final photon state, there is interference.
I've looking at this and at first I thought it was another way to codify 'which path information' and show how it can be controlled. But there is something about it I cannot fathom when I try to envision it.
In the first experiment there are two independently produced (incoherent) photons which one would not expect to interfere.
The second experiment somehow makes then coherent. I'm struggling with that.
Of course, I may be misunderstanding what you're describing ...
  • #41
vanhees71 said:
I always fall in this trap :-(. I always fail to translate the word "realism" from my standard every-day meaning, to describe what's real in the sense of the natural sciences, i.e., what's objectively observed in nature, while you used it in the philosophical sense, where it means "classical deterministic worldview", i.e., the contrary to what's really realistic.
Realism a la EPR (what I referred to) is not the philosophical one you mention. It is the one in which all particle properties are well-defined independent of the act of observation. Post-Bell, such realism is highly suspect, as thousands* of varied attempts to locate or deduce such values have failed.
When it comes to entanglement, what is "objectively observed" (the statistical predictions) is dependent on a future context which INCLUDES the nature of the observation. Thus your usage of the word "objectively" is completely counter to meaning of the result being observer independent a la EPR. What can be "objectively observed" is a correlation which is ONLY related to the observers' later choice of measurement basis, and therefore cannot be preexisting in time. That statement is correct even for the Bohmian program, which likewise posits the observer participates to affect the correlations.*By my best estimate.
  • #42
I hope you don't find a break necessary, but if you do, I hope it is a short one.
To cheer you up: Physicist walks into a bar... :smile:
Likes fresh_42
  • #43
I hope you don't refer to me. It's not meant unfriendly. I just ask for a concrete experiment since I don't think that one can discuss these issues clearly without a concrete experiment.
Likes weirdoguy
  • #44
The entire EPR paper is flawed. Even Einstein himself didn't like it for being too vague. He lamented that his argument is "buried in erudition" (or something like this).
Indeed that't the great achievement of Bell's studies: You can invent a class of models he calls "local realistic", which I'd call "local deterministic" to avoid the burnt word "realistic", that are in contradiction with QT and thus you can decide by experiments whether EPR's "realism" describes nature better or QT. Since the decision is a zillion to 0 for QT, I don't take EPR's "realism" as a "realistic description" but as the contrary. What's really realistic, i.e., in accord with all experience (among it some of the most accurate experiments ever) is QT not "EPR realism".
The observations on states involving entanglement are completely observer independent. It's only dependent on what's measured, i.e., it's dependent on with which "stuff" the observed object interacts in the process of state preparation and observation. Nothing is changed to the object by choosing which partial ensemble you like to observe. In principle you can decide for any choice long after the entire setup is gone, as long as you have an accurate record about all experimental data. In the Kim erasure experiment it's just the choice of the one or the other partial ensemble of measurement records that "decides" whether you see interference effects or not. That shows that this dependence of the outcome on the choice is an objective property of the system due by the entangled state it was prepared in.
Likes Mentz114
  • #45
That's a great paper (it appeared in APJ, i.e., a respected physics-didactics journal). I've nothing to add to their analysis. It's precisely what I always say: See particularly Eqs. (9a+b). There they explicitly write that the measurement is local, i.e., the projection operator describing the filtering is only acting on the measured part of the entangled system in accordance with locality of the interaction between measurement device and this measured part.
Also here, in principle you can choose to erase the which-way information in the erasure setup after everything is saved in a measurement protocol: The total ensemble doesn't show the interference effect, while choosing the subensemble where ##\mathcal{E}## registered the photon or the complementary one where the photon did not get registered, the interference effect is seen for each of these two subensembles.
Nowhere is an instantaneous collapse at a distance and also no retrocausality or subjectivity by the delayed choice. The particular setup with the source, all the beam splitters and detectors, objectively determines the (probabilistic!) outcome of the measurements. Also note with this setup you can make only the specific kind of delayed choice, i.e., "erasing or not erasing" the which-way information. Any other possibility of thinkable delayed choices needs a corresponding change of the experimental setup.
Indeed, what's objective according to QT depends on the specific experimental setup, and this is in contrast to the "deterministic view" of (E)PR, which makes this view "unrealistic" rather than being "realistic" as claimed by (E)PR.
  • #46
vanhees71 said:
The entire EPR paper is flawed...
It is a great paper that concludes with the same position you espouse: that the observer reveals a pre-existing local property. Of course, Bell showed us that is not a viable position.
Discussing this is the stuff for a different thread, so with this I will bow out.
  • #47
I don't espouse anything of the EPR paper. To the contrary I say that QT is correct and the EPR prejudice of predetermined values is flawed. The EPR paper is only hyped, because Einstein is a co-author, and ironically it doesn't even make Einstein's quibbles with QT clear (according to Einstein himself).
I follow the minimal interpretation, i.e., the measurement (not the observer who is not necessarily directly interacting with anything measured, he's only reading off a measurement protocol and chooses different sub-ensembles in the here discussed example) leads with the probabilities given by the QT formalism to the outcomes for the values of the measured observable, and nothing else. There's nothing hidden or anything. If, according to the state preparation, the observable as an indetermined value, then this observable is indetermined, and that's not because of lack of knowledge of the observer but that's inherent in nature, and it's described by the state (i.e., a statistical operator) the system is prepared in.
  • Quantum Physics
  • Quantum Physics
  • High Energy, Nuclear, Particle Physics
