Why is the Enthalpy of Neutralisation for HF Greater than 68KJ?
  • Thread starter theincrediblea
In summary, the enthalpy of neutralisation of HF is greater than 68KJ due to the fact that the enthalpy of ionization for weak acids is always greater than 0, resulting in a higher enthalpy of neutralization. This can be seen in the reaction of HF and OH- where the enthalpy of ionization is exothermic, leading to a higher enthalpy of neutralization.
theincrediblea
why enthalpy of neutralisation of HF is greater than 68KJ.
MY attempt
Enthalpy of neutralisation= Enthalpy of Ionisation + Δ(H+ + OH-)
Now,For very strong acid, enthalpy of Ionisation = 0,
Hence enthalpy of neutralisation= (H+ + OH-)= -13.7KCal
for weak acid, enthalpy of ionisation is always > 0
∴, enthalpy of neutralisation should always be less than 13.7 (57 KJ).
Please explain
Chemistry news on Phys.org
HF + OH- = F- + H2O
Enthalpy of this reaction = Enthalpy of neutralization of HF = Enthalpy of products - Enthalpy of reactants
which comes out to be greater than 68kJ. So, here evidently the enthalpy of of ionization of HF is EXOTHERMIC.
Hope this helps! :)
-Adithyan
That's not true.
Just because the acid dissociated long ago and the solution temperature got in equilibrium with the surroundings, doesn't mean enthalpy of ionization was zero.
thanks adithyan for ur help
further
The enthalpy of neutralisation is a measure of the energy released or absorbed when an acid and a base react to form a salt and water. It is a thermodynamic property that depends on the strength of the acid and base involved in the reaction.
In the case of HF, it is a weak acid, meaning that it does not completely ionize in solution. This means that the enthalpy of ionisation for HF is greater than 0. This leads to a larger contribution to the overall enthalpy of neutralisation, resulting in a higher value than the theoretical value of 13.7 kcal (or 57 kJ).
Furthermore, the strength of an acid is also related to its bond strength. HF has a very strong bond between the hydrogen and fluorine atoms, making it more difficult to break and release the hydrogen ion. This results in a higher enthalpy of ionisation and therefore a greater enthalpy of neutralisation.
In contrast, a strong acid like HCl has a weaker bond between the hydrogen and chlorine atoms, leading to a lower enthalpy of ionisation and a lower enthalpy of neutralisation. This is why the enthalpy of neutralisation for HF is greater than 68 kJ, as it is a weaker acid with a stronger bond.
What is the definition of enthalpy of neutralisation?
The enthalpy of neutralisation is the change in enthalpy that occurs when one mole of an acid reacts with one mole of a base to form a salt and water under standard conditions.
How is the enthalpy of neutralisation calculated?
The enthalpy of neutralisation is calculated by subtracting the enthalpy of the reactants from the enthalpy of the products. The enthalpies of the reactants and products can be determined using thermodynamic tables or by conducting experiments.
What factors can affect the enthalpy of neutralisation?
The enthalpy of neutralisation can be affected by the strength of the acid and base, the concentrations of the reactants, the temperature, and the pressure.
What is the significance of enthalpy of neutralisation in chemical reactions?
The enthalpy of neutralisation is important in understanding the energy changes that occur during acid-base reactions. It can also be used to determine the extent of a reaction and the efficiency of a neutralisation process.
How does the enthalpy of neutralisation relate to other thermodynamic properties?
The enthalpy of neutralisation is related to other thermodynamic properties, such as enthalpy of formation, enthalpy of combustion, and enthalpy of solution. It can also be used in conjunction with other thermodynamic calculations to determine the overall energy changes in a chemical system.
37K
