Entropy and Gasoline
Premium gasoline produces 1.23×108 J of heat per gallon when it is burned at a temperature of approximately 400ºC (although the amount can vary with the fuel mixture). If the car's engine is 25.0% efficient, three-fourths of that heat is expelled into the air, typically at 20.0ºC.
a) If your car gets 35.0 miles per gallon of gas, by how much does the car's engine change the entropy of the world when you drive 1.00 mile?
b) Does it decrease or increase the entropy of the world?
ΔS = ΔSHOT + ΔSCOLD
a) ΔS = ΔSHOT + ΔSCOLD
ΔS = -((.75*(1.23*108 J/gal)*(1 gal/35 mile)*(1 mile))/(400+273 K) + ((.75*(1.23*108 J/gal)*(1 gal/35 mile)*(1 mile))/(20+273 K)
ΔS = -3916 J/K + 8996 J/K
ΔS = 5079 J/K
b) Entropy increases (positive value for part a)
Would both ΔSHOT and ΔSCOLD be multiplied by .75, or would one be multiplied by the .25 efficiency?
Answers and Replies
rude man
Insights Author
792
ΔS = ΔSHOT + ΔSCOLD
correct
ΔS = 5079 J/K
Answer is incorrect.
What is the heat going into the engine and its temperature? What is the heat leaving the engine and its temperature?
Neither gets multiplied by 0.25.
correct
The heat going into the engine is 293 K and the heat leaving the engine is 673 K, so if I just multiply both by .75 (like in my attempt), will that give me the correct answer?
ΔS = ((.75*(1.23*108 J/gal)*(1 gal/35 mile)*(1 mile))/(400+273 K) - ((.75*(1.23*108 J/gal)*(1 gal/35 mile)*(1 mile))/(20+273 K)
ΔS = 3916 J/K - 8996 J/K
ΔS = -5079 J/K
So the entropy of the world decreases?
rude man
Insights Author
792
The heat going into the engine is 293 K and the heat leaving the engine is 673 K, so if I just multiply both by .75 (like in my attempt), then switch the minus sign, will that give me the correct answer?
ΔS = -5079 J/K
Why are you multiplying the heat going into the engine by 0.75? Isn't all of the heat going into the engine? Whereas, isn't some of the heat that went into the engine not going out of the engine but changed into work instead?
Oh, and I just now noticed: you have ΔS of the hot side positive and ΔS of the cold side negative. How come that?
Sorry, by mistake I have added.
Oh! So, only ΔSCOLD should include .75! I switched back the signs as I had them before--I accidentally mixed them up.
ΔS = ΔSHOT + ΔSCOLD
ΔS = -((1.23*108 J/gal)*(1 gal/35 mile)*(1 mile))/(400+273 K) + ((.75*(1.23*108 J/gal)*(1 gal/35 mile)*(1 mile))/(20+273 K)
ΔS = -5221 J/K + 8996 J/K
ΔS = 3774 J/K
rude man
Insights Author
792
That's a lot better! Everything correct now.
Likes 1 person
Related Threads on Entropy and Gasoline
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
