Entropy Calc: Solving for 100 Mol Gas
In summary, the problem involves two isolated containers of volumes V1 and V2, enclosing ideal single atom gas at the same pressure p. Each container initially contains 100 mol of gas and has a temperature of T1=293K and T2=308K respectively. After connecting the containers, an equilibrium is achieved. Using the equations dQ=dE+dW, dS=dQ/T, dE=3/2 nRdT, and pV=nRT, the entropy of the system is calculated to be (delta)S=1153.77 J/K. However, there is concern that the result may be too high and further calculations are needed to determine if the volumes mix or remain the same. The final
ljeonjko
Two isolated containers, of volumes V1 and V2, enclose ideal single atom gas at the same pressure p. The number of particles in each container is equal, the temperature of gas in container one is T1=293K and the temperature of gas in container two is T2=308K. An equilibrium is acheived by connecting the two containers. Calculate the entropy of the system if each container initially contained 100 mol of gas.
dQ=dE+dW
dS=dQ/T
dE=3/2 nRdT
pV=nRT
Basically, I've solved the problem, with the result of (delta)S=1153.77 J/K. Mathematically speaking, it checks out, but I doubt, along with a few of my colleagues, that the result is much too great. I've also searched the wikipedia for the order of magintudes which shows that the standard entropy of 1 mole of graphite is 5.74 J/K. This means that, for 200 moles of the gas, the result should be more or less accurate.
I'd greatly appreciate if anyone could double check this. Thank you :)
In terms of the initial pressure p, what did you get for the initial volumes V1 and V2? What was the final temperature? In terms of p, what was the final pressure?
Can you please just check and see if the result matches. The concern is whether or not the volumes "mix", meaning V1 becomes V1+V2 just like V2 becomes V1+V2 or if the volumes stay the same, as the problem is not clear on the issue. If we calucate that the voulmes mix, the result should be 1153.77 J/K, otherwise, the result is 0.777 J/K.
Please show the details of what you did.
Mixing is irrelevant, because it is the same gas in both containers. Did you remember to use Cp and not Cv?
Starting from
dQ=dE+dW
it's easy to obtain
S=nCvln(Tf/Ti)+nRln(Vf/Vi)
using the three other equations.
Tf is obtained through Q1+Q2=0. From there, it's just basic math.
The main question still remains whether or not the Vf1 and Vf2 are the same as Vi1 and Vi2 respectively. If they are, the result is 0.777 J/K and if they are not, the result is 1153.77 J/K.
Take as the basis of zero entropy 273 K and pressure p.
Initial entropy gas relative to basis state = ##100C_p\ln(293/273)+100 C_p \ln(308/273)##
Final entropy of gas relative to basis state = ##200 C_p(300.5/273)##
##\Delta S=100C_p\ln(300.5/293)+100C_p\ln(300.5/308)=1.295## J/K
Chet
1. What is entropy?
Entropy is a measure of the disorder or randomness in a system. It is a thermodynamic property that describes the amount of energy that is unavailable to do work.
2. How is entropy calculated?
Entropy can be calculated using the formula S = k ln W, where S is the entropy, k is the Boltzmann constant, and W is the number of microstates or ways in which a system can be arranged.
3. What is the significance of solving for 100 mol gas in entropy calculations?
Solving for 100 mol gas allows us to determine the change in entropy for a larger system, which is useful in understanding the behavior of gases in real-world applications.
4. How does entropy relate to the second law of thermodynamics?
The second law of thermodynamics states that the total entropy of a closed system will always increase over time. This means that natural processes tend to move towards a state of higher disorder, or higher entropy.
5. Can entropy be negative?
In thermodynamics, entropy is always a positive value or zero. A negative entropy would imply a negative disorder or randomness, which is not possible. However, in other fields such as information theory, entropy can be negative as it represents the amount of uncertainty or information in a system.
19K
