Temperature Change in Partitioned Tank with Ideal Gas Upon Removal of Partition
In summary, when a partitioned tank containing an ideal gas is opened, the temperature remains unchanged due to free expansion where no work is done and no heat is exchanged with the environment. However, when a can is discharged into the atmosphere, the expanding gas must do work to push the opposing air away, causing a loss of kinetic energy and a decrease in temperature. This is due to conservation of energy and can also be observed when spraying into a vacuum. Even with a liquid propellant, such as in a can of freon or butane lighter fluid, the temperature drop is more significant as the latent heat of vaporization absorbs environmental heat.
74baja
Hi all,
Sorry if this is posted in the wrong place, I'm new here.
I have a thermodynamics question. Why is the temperature change 0 in the case of a partitioned tank containing an ideal gas when the partition is removed? This seems to run counter to the idea of an aerosol spray can getting cold when it is discharged.
Thank you
74baja said:
Hi all,
Thank you
Welcome to PF, 74baja! :smile:
It is called "free expansion" (look it up).
The expanding gas does not do any work, since there is no counter pressure.
Since there is also no exchange of heat with the environment, the change in internal energy is zero (dU=dQ+dW=0).
This is conservation of energy.
Since the internal energy of an ideal gas depends only on T (U=nCvT), T must have remained constant.
I see, thank you. So, the change in temperature when a can is discharged into the atmosphere is due to the opposing pressure of the atmosphere, and the work that the can gas must do to overcome it?
Thanks
Yes.
The expanding gas from the can has to push the opposing air away.
As a consequence the molecules lose kinetic energy, which means that the temperature drops.
Thanks
No. Even if you sprayed into a vacuum, you would feel a colder can.
By conservation of energy the kinetic energy acquired by the ejected propellant molecules has to come from somewhere, and that somewhere is the loss of heat energy (3kT/2 per molecule) of the remaining pressurized propellant.
If the propellant is a liquid, the effect is much more pronounced since then the latent heat of vaporization is the major absorber of environmental heat. A can of freon (like you can't get any more) is a good example. So is butane lighter fluid.
What is entropy in a partitioned tank?
Entropy is a measure of disorder or randomness in a system. In a partitioned tank, entropy refers to the distribution of particles or molecules within each section of the tank.
How does the partitioning of a tank affect entropy?
The partitioning of a tank can affect entropy by limiting the movement and distribution of particles within each section. This can result in a decrease in entropy as the particles become more organized.
What factors can increase entropy in a partitioned tank?
Factors that can increase entropy in a partitioned tank include increasing the number of particles or molecules, increasing the temperature, and removing the partitions to allow for more free movement of particles.
How is entropy related to the second law of thermodynamics?
The second law of thermodynamics states that the total entropy of a closed system will always increase over time. In a partitioned tank, this means that the overall entropy of the system will increase as the particles become more evenly distributed among the partitions.
What is the practical application of studying entropy in partitioned tanks?
Studying entropy in partitioned tanks can help us understand and predict the behavior of complex systems, such as chemical reactions or biological processes. It is also important in fields such as thermodynamics, physics, and chemistry, and can be used in the design and optimization of industrial processes.
  • Thermodynamics
10K
