Entropy variation during free expansion
In summary, for a system consisting of n moles of ideal gas doing a free expansion to vacuum from volume V to 2V, the change in entropy for the gas is zero and the change in entropy for the universe is also zero. If the process is reversible and isothermal, the change in entropy for the gas is \Delta S = nRln2 and the change in entropy for the universe is also \Delta S = nRln2.
becko
27
A system that consists of [tex]n[/tex] moles of ideal gas does a free expansion (to the vacuum) from a volume [tex]V[/tex] to a volume [tex]2V[/tex]. a) What is the variation of entropy of the gas?; b) of the universe?; c) if the expansion was reversible and isothermal, what would be the variation of the entropy of the gas?; d) of the universe?
Ideal Gas Law: [tex]PV=nRT[/tex]
Conservation of Energy: [tex]\texttt{d}U=T\texttt{d}S-p\texttt{d}V[/tex]
a)
not sure how to do this. I think it should be zero.
b)
I know that the entropy is additive, so that the change of entropy in the universe is just the change of entropy in the system, plus the change outside the system. Supposedly there is no change of entropy outside the system, so that the answer to this question should be the same as a).
c)
Since the temperature doesn't change and this is an ideal gas, [tex]\texttt{d}U=0[/tex]. Therefore
[tex]\texttt{d}S=\frac{p\texttt{d}V}{T}[/tex]
Using the ideal gas law:
[tex]\texttt{d}S=\frac{nR\texttt{d}V}{V}[/tex].
Integrating gives the result:
[tex]\Delta S=nR\texttt{ln}2[/tex]
d)
The same as in c).
Please, help me with a) and b). I believe the answer should be zero, but then I think that I can travel from the initial state to the final state through the reversible and isothermal line, just as in c) and d), in which case the answer to a) and b) should be the same as in c) and d) (since entropy is a function of state). Can someone clear this up for me?
Hello!
For part a), you are correct that the change in entropy for the gas itself is zero. This is because the process is a free expansion to vacuum, meaning that there is no external pressure acting on the gas and thus no work done. Since the change in internal energy is also zero (no change in temperature or number of moles), the change in entropy for the gas is zero according to the equation \Delta S = \frac{Q}{T}.
For part b), you are also correct that the change in entropy for the universe is also zero. This is because the process is adiabatic (no heat transfer) and reversible (no increase in entropy due to irreversibilities). Therefore, the entropy of the universe remains constant.
For part c), you are correct in your approach. Since the process is isothermal and reversible, the change in internal energy is zero and the change in entropy is given by \Delta S = \frac{Q_{rev}}{T}. Since the process is reversible, the heat transfer is equal to the work done, which can be calculated using the ideal gas law. Therefore, the change in entropy for the gas is \Delta S = nRln2.
For part d), the change in entropy for the universe is also \Delta S = nRln2. This is because the process is isothermal and reversible, so the change in entropy for the gas is the same as the change in entropy for the universe.
I hope this helps clarify things for you. Keep up the good work!
I would like to clarify that the variation of entropy during free expansion is not zero. In fact, it is an irreversible process and the entropy of the gas will increase during this expansion. This is because the gas is expanding into a larger volume, leading to a decrease in its density. As a result, there is an increase in the number of accessible microstates for the gas molecules, leading to an increase in entropy. The exact value of the entropy change can be calculated using the formula \Delta S = nR\texttt{ln}(V_f/V_i), where V_f and V_i are the final and initial volumes respectively.
As for the variation of entropy in the universe, it is important to note that the concept of entropy applies to the entire universe, not just to the gas system. While the entropy of the gas increases during free expansion, the entropy of the surroundings (or the vacuum in this case) remains constant. This means that the overall entropy change in the universe is positive, as the gas system has contributed to an increase in entropy. This is in line with the second law of thermodynamics, which states that the total entropy of a closed system can never decrease.
In the case of a reversible and isothermal expansion, the entropy of the gas will remain constant as the temperature and pressure are constant. However, there will still be an increase in the entropy of the universe, as the gas is expanding into a larger volume and contributing to an increase in the number of accessible microstates. Therefore, the answers to c) and d) should be the same as the answers to a) and b), respectively.
I hope this clarifies the concept of entropy variation during free expansion for you. If you have any further questions, please feel free to ask.
1. What is "Entropy variation during free expansion"?
Entropy variation during free expansion is a concept in thermodynamics that describes the change in entropy of a system during a process in which the system expands without any external work being done on it.
2. How does entropy change during free expansion?
During free expansion, the entropy of a system increases because the particles in the system are able to move to a larger volume, leading to an increase in the number of microstates available to the system. This increase in microstates leads to an increase in entropy.
3. What is the relationship between temperature and entropy during free expansion?
During free expansion, the temperature of a system remains constant, while the entropy increases. This is because there is no change in internal energy, but the volume increases, leading to an increase in entropy.
4. Why is entropy important in understanding free expansion?
Entropy is important in understanding free expansion because it helps us predict the direction of spontaneous processes. In free expansion, the increase in entropy is a result of the system moving towards a state of higher disorder, which is the direction of most spontaneous processes.
5. Can entropy decrease during free expansion?
No, entropy cannot decrease during free expansion. The second law of thermodynamics states that the total entropy of a closed system always increases or remains constant. Therefore, in free expansion, where there is no external work being done on the system, the entropy will either stay constant or increase.
