Epoxy anchors
  • Thread starter jack in oz
Hi All,
my first post on this fantastic forum.
I am attaching a timber ledger to a concrete pool with 10mm stainless-steel threaded rods at 900mm centres. I am using a polyester adhesive made by ramset to anchor the rods into the concrete. The adhesive instructions call for the rod to be embedded in a 90mm deep hole. However, the engineer who designed the pool will only allow me to drill 70mm deep because the reinforcing bars are embedded 75mm from the outside of the shell.
My question is: do I simply reduce the distance between the threaded rods by the ratio 70/90 (i.e. 700mm centres) to achieve the same overall strength, or is it more complicated than that?
Appreciate any advice.
Regards,
Jack
5,419
You can hire bar locater probes to find the spaces between the bars and drill deeper there.
Look up 'concrete cover meter' in you local YP.
thanks Studiot, I'll look into it.
Related Threads for: Epoxy anchors
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Hot Threads
