Exploring the EPR Paradox: What Does "Simultaneous Reality" Mean?
In summary: This is the well-known spectral theorem and the corresponding classical case is the representation of the state by a point in the phase space.In summary, the EPR paradox states that the elements of physical reality cannot be determined solely through philosophical considerations, but must be confirmed through experiments and measurements. The concept of "simultaneous reality" refers to the ability to determine the values of two physical quantities at the same time, which is only possible if the corresponding operators commute. This paradox challenges the idea that position and momentum can have simultaneous reality, as there is no normalizable eigenstate for either of them.
victor94
I'm reading the paper of the EPR paradox and I'm confused in the meaning of this:
"The elements of the physical reality cannot be determined by a priori philosophical considerations, but must be found by an appeal to results of experiments and measurements......when the operators corresponding to two physical quantities do not commute the two quantities cannot have simultaneous reality".
What it means "simultaneous reality"?
Paper: https://journals.aps.org/pr/abstract/10.1103/PhysRev.47.777
Any help will be apreciated.
Thanks.
In the context of the paper it means that position and momentum is certain at the same time (which of course contradicts Heisenberg's uncertainty principle).
Wrong, it is not in contradiction with the uncertainty principle. They could be well-defined and certain in reality, but it could be impossible, with the means of quantum theory, to prepare states which violate the uncertainty relations. So, in every repetition of the experiment the same preparation procedure would give different positions and momentum values, but in each repetition they could be well-defined.
So, you have to refer here to other things, like Kochen-Specker or Bell.
Likes zonde
Thanks.
For EPR (the paper is quite enigmatic, and Einstein himself didn't like it too much) observables have a reality if they have a determined value. If you like to get completely confused read Bohr's answer (with the same title) ;-)).
This means for an observable to have a determined value you have to be able to prepare a system in a state that is described by an eigenstate of the self-adjoint operator that represents the observable. Note that it must be a true normalizable Hilbert-space vector to be a proper state, and thus according to EPR position and momentum are never "real", because there is no normalizable eigenstate for either of them.
It also implies that for being able to make two observables "real simultaneously" you have to be able to always prepare a common eigenstate of the corresponding self-adjoint operators and this is, in this generality, only possible, if these operators commute.
Note that for the complete determination of the quantum state you have to prepare the system in a state described by a simultaneous eigenvector of a complete set of compatible self-adjoint operators, describing corresponding compatible observables.
1. What is the EPR paradox?
The EPR (Einstein-Podolsky-Rosen) paradox is a thought experiment proposed by Albert Einstein, Boris Podolsky, and Nathan Rosen in 1935. It challenges the principles of quantum mechanics and the idea of "simultaneous reality".
2. What does "simultaneous reality" mean?
"Simultaneous reality" refers to the concept that two seemingly separate particles can be connected in a way that their properties are perfectly correlated, even when separated by large distances. This goes against our everyday understanding of reality, where objects can only affect each other through direct interaction.
3. What implications does the EPR paradox have?
The EPR paradox has major implications for our understanding of quantum mechanics and the nature of reality. It challenges the idea of local realism, which states that objects can only affect each other through direct interaction. It also raises questions about the role of observation and measurement in determining reality.
4. How has the EPR paradox been tested?
Several experiments have been conducted to test the predictions of the EPR paradox, including the Bell test experiments. These experiments have shown that the predictions of quantum mechanics are correct and that there is indeed a non-local connection between particles, supporting the concept of "simultaneous reality".
5. What are the implications of the EPR paradox for technology?
The EPR paradox has implications for the development of quantum technologies, such as quantum computing and quantum encryption. By understanding and harnessing the non-local connections between particles, we may be able to create more powerful and secure technologies that could revolutionize various industries.
  • Quantum Interpretations and Foundations
  • Beyond the Standard Models
