Equation of a line
  • Thread starter embury
embury
I need to find the equation for the line that passes through the pont (-1, 2, -3) in the direction of the vector (1,-1,-1)
The equation needs to be in the form v(t)=v subscript 0 + tv
I know how to find the equation of a line passing through two points, but I have no idea how to find the equation with only one point heading in the direction of a vector. I'm not really looking for the answer, I'm looking for an explanation on how to find the equation of a line given one point in the direction of a vector. Any help would be appreciated. Thank you.
I think I've found the solution, but I'm not sure. v=(1,-1,-1) and V subscript 0 = (-1,2,-3), therefore the equation of the line is (-1,2,-3) + t(1,-1,-1). Is this right?
Answers and Replies
KoGs
106
Take a look at dot products and cross products.
berkeman
Mentor
64,147
15,364
I'm not sure if your answer is correct, but one way to check it is to use what you already know -- how to find the equation based on two points. Since the line is in the direction of (1,-1,-1) from point (-1,2,-3), then a 2nd point on the line would just be (1,-1,-1) away from the first point, right?
embury
Thank you. I guess this question isn't that difficult. For some reason I thought it was harder than it was. :blushing: Thank you guys.
HallsofIvy
43,021
971
Actually, after the very good response to the "eigenvalue" question, yes, you should be embarrased!:smile:
Suggested for: Equation of a line
  • Last Post
  • Last Post
  • Last Post
  • Last Post
