Solving Surface Equation Homework
  • Thread starter athrun200
  • Tags
    Surface
In summary, a surface equation is a mathematical equation used to describe the relationship between points on a surface. When solving a surface equation homework problem, the steps include identifying the type of equation, simplifying, isolating the variable, and solving for it. Surface equations can also be solved graphically and have many real-life applications. Common mistakes when solving surface equations include forgetting to combine like terms, using incorrect values, and misinterpreting the graph.
athrun200
277
It seems very obvious that after rotation, it becomes a circle, so how to write it out mathematically?
That I don't know the general equation of a surface.
Is [itex]y^2+x^2=f^2(x)[/itex] the answer?
Yes, this is the general equation for a circle
[tex]f(x)²=x²+y²=r²[/tex]
As seen in the figure, f(x)=radius
And from polar coordinates you can get the equation:
[tex]x=r*cos(\Theta)[/tex]
[tex]y=r*sin(\Theta)[/tex]
[tex]x²+y²=r²(cos²(\Theta)+sin²(\Theta))=r²[/tex]
What is a surface equation?
A surface equation is a mathematical equation that describes the relationship between the coordinates of points on a surface. It is used to model and solve problems related to surfaces in mathematics and science.
What are the steps for solving a surface equation homework problem?
The steps for solving a surface equation homework problem are as follows:
  1. Identify the type of surface equation (e.g. linear, quadratic, etc.)
  2. Simplify the equation by combining like terms
  3. If needed, use algebraic techniques to isolate the variable of interest
  4. Plug in known values for the remaining variables
  5. Solve for the unknown variable
Can surface equations be solved graphically?
Yes, surface equations can be solved graphically by plotting the equation on a coordinate plane and finding the points of intersection with other lines or curves. This method is useful for visualizing the solutions and can be used to check the accuracy of algebraic solutions.
What are some real-life applications of surface equations?
Surface equations have many real-life applications, including:
  • In physics, they can be used to model the motion of objects through space
  • In engineering, they can be used to design and analyze structures and surfaces
  • In computer graphics, they are used to create 3D models and animations
  • In chemistry, they can be used to describe the shapes of molecules and predict their properties
What are some common mistakes when solving surface equations?
Some common mistakes when solving surface equations include:
  • Forgetting to combine like terms before solving
  • Not isolating the variable of interest before plugging in known values
  • Using incorrect values or units for the known variables
  • Misinterpreting the graph of the equation or not plotting it correctly
  • Forgetting to check the solution by plugging it back into the original equation
