• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Equation order x^3
  • Thread starter danai_pa
I can't find the solution of this equation
Cx^3-2Ex+2k = 0
please help
92
Let's call x=u+v, then you obtain (u+v)^3+A(u+v)+B=0 (A=-2E/C; B=2k/C)
then, solving some products etc.. you have: (u^3+v^3+B)+(u+v)(3uv+A)=0
put it into a system
1) u^3+v^3=-B
2) 3uv=-A (u+v cannot be=0)
We turn the second equation into u^3*v^3=-A^3/27
so we can solve a II° eq. since we have two number whose sum and product are known, then you take the III root and sum them, then you use Ruffini to lower the degree of the original equation, once you found one solution. Then you can easily solve the remaining II deg. eq.
Ok I made the thing a bit simple, there are some problems with logics, complex solutions etc.
If you want something more precise I suggest to search the net.
HallsofIvy
41,713
876
That is, in fact, the general reduced third degree equation. There is a standard formula, called "Cardano's formula". Maxos was leading you through it. I recommend you google on "Cardano's formua" or "Cubic formula" to see the whole thing.
147
http://www.ping.be/~ping1339/cubic.htm [Broken]
Here it is
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
