Equation with fractions
  • Thread starter Mkorr
Solve the following equations:
[tex]\frac{1}{x-1} -\frac{1}{x-2} = \frac{1}{x-3} - \frac{1}{x-4}[/tex]
See above.
Rearrangement gives
[tex]\frac{1}{x-1} -\frac{1}{x-2} - \frac{1}{x-3} + \frac{1}{x-4} = 0[/tex]
Conversion to same denominator gives
[tex]\frac{(x-2)(x-3)(x-4)}{(x-1)(x-2)(x-3)(x-4)} -\frac{(x-1)(x-3)(x-4)}{(x-1)(x-2)(x-3)(x-4)} - \frac{(x-1)(x-2)(x-4)}{(x-1)(x-2)(x-3)(x-4)} + \frac{(x-1)(x-2)(x-3)}{(x-1)(x-2)(x-3)(x-4)} = 0[/tex]
Writing as one fraction gives
[tex]\frac{(x-2)(x-3)(x-4) -(x-1)(x-3)(x-4) - (x-1)(x-2)(x-4) + (x-1)(x-2)(x-3)}{(x-1)(x-2)(x-3)(x-4)} = 0[/tex]
Partially multiplying binomials gives
[tex]\frac{(x^{2} - 5x + 6)(x-4) -(x^{2}-4x +3)(x-4) - (x^{2} - 3x +2)(x-4) + (x^{2} - 3x + 2)(x-3)}{(x-1)(x-2)(x-3)(x-4)} = 0[/tex]
Complete multiplication (just looking at the denominator for simplification) gives
[tex]\frac{x^3 - 4x^2 - 5x^2 + 20x + 6x - 24 - (x^3 - 8x^2 + 16x - 12) - (x^3 - 7x^2 - 12x + 2x - 8) + x^3 - 6x + 9x + 2x -6}{(x-1)(x-2)(x-3)(x-4)} = 0[/tex]
Removal of the parenthesis gives
[tex]\frac{x^3 - 4x^2 - 5x^2 + 20x + 6x - 24 - x^3 + 8x^2 - 16x + 12 - x^3 + 7x^2 + 12x - 2x + 8 + x^3 - 6x^2 + 9x + 2x -6}{(x-1)(x-2)(x-3)(x-4)} = 0[/tex]
Adding together everything gives
[tex]\frac{31x - 10}{(x-1)(x-2)(x-3)(x-4)} = 0[/tex]
Rewriting
[tex]\frac{1}{(x-1)(x-2)(x-3)(x-4)} \cdot (31x - 10) = 0[/tex]
The left factor equals to zero lacks a solution so
31x - 10 = 0
x = 10/31
but this is clearly wrong as checking does not produce the equality when checked.
Answers and Replies
eumyang
1,347
The 2nd polynomial:
x3 - 8x2 + 16x - 12
should be
x3 - 8x2 + 19x - 12
The 3rd polynomial:
x3 - 7x2 - 12x + 2x - 8
should be
x3 - 7x2 + 12x + 2x - 8 or x3 - 7x2 + 14x - 8
The last polynomial:
x3 - 6x + 9x + 2x -6
should be
x3 - 6x2 + 9x + 2x -6 or x3 - 6x2 + 11x - 6
HallsofIvy
41,847
966
By the way- when you combine all the fractions, you will eventually set it equal to 0, then multiply both sides by the common denominator, eliminating it. It is simpler just to get it equal to 0, then multiply both sides of the equation by that common denominator immediately. That is, go from
to
[tex]\frac{1}{x-1} -\frac{1}{x-2}- \frac{1}{x-3}+ \frac{1}{x-4}= 0[/tex]
to
[tex](x-2)(x-3)(x-4)- (x-1)(x-3)(x-4)- (x-1)(x-2)(x-4)+ (x-1)(x-2)(x-3)= 0[/tex]
It at least saves writing all of those fractions!
Related Threads on Equation with fractions
  • Last Post
  • Last Post
  • Last Post
  • Last Post
12K
  • Last Post
14K
