Equation with two variables
  • Thread starter MSG100
Problem:
Find all the positive integer solutions where x and y are odd numbers, to the equation: 17x+11y=1000
Attempt of solution:
First attempt:
With Diophantine equation have gotten the answers:
x=2000
y=-3000
and the general solutions will be:
x=2000-11k
y=-3000+17k
Now I don't know what to do.
Second attempt:
If I skip the Diophantine solution and do it like this:
y=(1000-11x)/17
Now I see that x has to be in the interval 0≤x≤58 if y should be positive.
If I test all the odd numbers in the interval I'll get 3 solutions when both x and y are positive and odd numbers. The solutions are:
(x, y) = (9, 77), (31, 43) and (53, 9)
This solutions (which should be the right answer) takes alot of time because you have to test all odd numbers between 0 to 58 (29 different numbers).
I need help to find an easier solution.
Answers and Replies
Dick
26,263
619
Problem:
First attempt:
x=2000
y=-3000
x=2000-11k
y=-3000+17k
Second attempt:
y=(1000-11x)/17
If you don't want to check all those numbers you should use your Diophantine solution. You just have to figure out what values of k will make both x and y positive. There aren't that many.
Thanks, that makes sense!
Then I just have following numbers k= 177, 178, 179, 180, 181 to make x and y positive and only k= 177, 179, 181 to make them positive AND odd.
Related Threads on Equation with two variables
18K
  • Last Post
  • Last Post
