Relative Motion of Planet to Star: Gm1m2/r^3 - Gm1m2/r^3 = 0
In summary, the gravitational pull on a planet is equal to the force of gravity due to the mass of the star divided by the planet's radius. This is because gravity is a force that acts in a direction perpendicular to the radius vector. The equation of motion for the planet must be subtracted from the equation of motion for the star in order to calculate the relative motion of the two.
Jadaav
175
Suppose we have a star and a planet with radius vectors r1 and r2 respectively in a fixed inertial coordinate frame. Relative position of planet from sun is r = r2 - r1
Why is the gravitational pull felt by the planet equals to F = Gm1m2 / r^2 * ( -r/r ) ?
Therefore, F= Gm1m2/r^3
Secondly, we want to find the relative motion of the planet with respect to the star.
Why is it that we have to substract the equation of motion of the star from that of the planet ?
m1 = mass of star
m2 = mass of planet
m2a2 = -Gm1m2r/r^3 ------ 1st eq
m1a1 = Gm1m2/r^3 -------- 2nd eq
Finally, a = G(m1+m2)r/r3
Astronomy news on Phys.org
That is just the way gravity works. The r in the numerator is a vector here.
That is wrong.
The relative distance is r = r2 - r1, as you wrote above. If you want to calculate the second time-derivative of that, the minus sign stays there.
OK
I did a mistake in typing : F= Gm1m2r/r^3
Thanks a lot :)
The magnitude of the force is F = Gm1m2 / r^2. The part in parenthesis should be the radius vector (r2-r1) divided by the magnitude of the difference. It just gives a direction to the gravitational force vector.
Should include the radius vector in the numerator, same as above.
m1 = mass of star
m2 = mass of planet
Both objects are orbiting their combined center of mass. You can often get away with saying the planet orbits the star because the combined center of mass is usually very near the center of mass of the star (if you add the Earth's mass to the Sun's mass, the total will still be very close to the Sun's mass), but the true situation is that both the planet and the star are orbiting their combined center of mass (with the resulting wobble of the star being one of the ways we detect planets around other stars).
Thanks a lot BobG.
Really appreciated :)
1. What is the relative motion of a planet to a star?
The relative motion of a planet to a star is the movement of the planet in relation to the star it is orbiting. This motion is influenced by the gravitational pull of the star and the planet's own inertia.
2. How is the relative motion of a planet to a star calculated?
The relative motion of a planet to a star is calculated using the formula Gm1m2/r^3 - Gm1m2/r^3 = 0, where G is the gravitational constant, m1 and m2 are the masses of the planet and star respectively, and r is the distance between them.
3. Why is the relative motion of a planet to a star equal to zero?
The relative motion of a planet to a star is equal to zero because of the law of conservation of momentum. This law states that the total momentum of a system remains constant unless acted upon by an external force. In this case, the gravitational force between the planet and star is the only force acting on them, so their relative motion remains constant.
4. How does the relative motion of a planet to a star affect the planet's orbit?
The relative motion of a planet to a star determines the shape and speed of the planet's orbit. If the relative motion is zero, the planet will have a stable circular orbit. If the relative motion is not zero, the orbit will be elliptical and the planet's speed will vary as it moves closer or further away from the star.
5. Can the relative motion of a planet to a star change?
Yes, the relative motion of a planet to a star can change if there is an external force acting on the system, such as the gravitational pull of another celestial body. This can cause the planet's orbit to become more elliptical or even change its path around the star entirely.
  • Astronomy and Astrophysics
