Equilibrium practice final exam problem
In summary, the tension in the cable supporting a 17.674 kg horizontal beam at a 60 degree angle is 5.10 N. The equation used to solve for this tension was \sum \tau = 0 \Rightarrow 0.5*17.674*9.81 - T\sin120*2 = 0. It is important to double check equations and units when solving physics problems.
Californiarol
A 17.674 kg 2.0m long horizontal uniform beam is hinged at one end and it is supported at the other end by a cable that makes an angle of 60 degrees to the horizontal.
Calculate the tension in the cable when it has been shortened so that the beam makes an angle of 60 degrees to the horizontal.
[tex]\sum F_{x}=0[/tex]
[tex]\sum F_{y}=0[/tex]
[tex]\sum \tau=0[/tex]
After finding the equations using [tex]\sum F_{x}=0[/tex] and
[tex]\sum F_{y}=0[/tex], I realized that we only need that [tex]\sum \tau=0[/tex].
So working with that, I got
[tex]\sum \tau=0 \Rightarrow \1cos60*17.674*9.81-Tsin120*2=0 [/tex]
Solving for T would give T = 50.05 but the answer booklet says its 5.10. Any help would be appreciated. Thanks!
Thank you for your post. I believe the discrepancy in your calculation may be due to a few errors in your equations. Firstly, when using \sum \tau=0, the equation should be set equal to zero, so it should be written as:
\sum \tau = 0 \Rightarrow 1\cos60*17.674*9.81 - T\sin120*2 = 0
Additionally, when solving for T, the value for the cosine term should be 0.5, not 1. So the correct equation should be:
Solving for T using this equation will give the correct answer of 5.10 N. I hope this helps. Remember to always double check your equations and units when solving physics problems. Good luck with your studies!
I would first check to make sure that all units are consistent in the equation. It appears that you may have used the wrong unit for the length of the beam. Instead of using 2.0m, you may have used 2.0cm. This would result in a significantly smaller value for T.
I would also recommend double-checking your calculations to ensure that there are no errors. This could include rounding errors or mistakes in the trigonometric functions.
If the units and calculations are correct, then I would suggest considering any external forces that may be acting on the beam, such as the weight of the beam itself. This could affect the tension in the cable and result in a different value for T.
Overall, it is important to carefully check all aspects of the problem and calculations to ensure an accurate solution.
FAQ: Equilibrium practice final exam problem
What is an equilibrium practice final exam problem?
An equilibrium practice final exam problem is a question or scenario that tests a student's understanding of the concept of equilibrium in chemistry. It usually involves a chemical reaction in which reactants are converted to products and the system reaches a state of balance.
Why is understanding equilibrium important in chemistry?
Equilibrium is a fundamental concept in chemistry that helps us understand how reactions occur and how we can manipulate them to achieve desired outcomes. It also plays a crucial role in many industrial processes and natural phenomena.
What are the key components of an equilibrium practice final exam problem?
An equilibrium practice final exam problem typically includes information about the reactants and products involved in a chemical reaction, their respective concentrations or pressures, and the equilibrium constant (K). It may also provide additional information such as temperature and volume.
How can I approach solving an equilibrium practice final exam problem?
First, carefully read and analyze the problem to identify the given information and what is being asked. Then, use the equilibrium expression and the given values to calculate the concentrations or pressures of all species at equilibrium. Finally, check if the calculated values satisfy the equilibrium condition (Q = K) and make any necessary adjustments.
What are some common mistakes to avoid when solving an equilibrium practice final exam problem?
Some common mistakes to avoid include using incorrect values for the equilibrium constant, not paying attention to units, not considering the direction of the reaction, and not double-checking the calculated values with the given information. It is also important to carefully follow the correct mathematical steps and show all work.
