1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Equilibrium problem: sliding door
  1. Sep 13, 2010 #1
    There is a sliding door lifted at a constant rate by two cables, A and B. The sides of the door fit loosely into grooves in the walls.
    Dimensions of door: 9 ft tall by 10 ft wide
    Weight of the door: 200 lbs
    Cable A is attached at the top of the door, 2 ft from the left side
    Cable B is attached at the top of the door, 2 ft from the right side
    The coefficient of kinetic friction between the door and grooves is 0.3
    Suppose cable B breaks. What force must cable A exert to continue raising the door at a constant rate?
    2. Relevant equations
    Equilibrium equations:
    [tex]\sum[/tex]Fx = 0, [tex]\sum[/tex]Fy = 0, [tex]\sum[/tex]M = 0
    Friction equation (N is force normal to surface):
    f=[tex]\mu[/tex] * N
    3. The attempt at a solution
    It seems as if I don't have enough information to solve the problem.
    To highlight the difficulty I have chosen to sum the moments about the center of mass of the door.
    [tex]\sum[/tex]Fx = Nleft - Nright = 0
    [tex]\sum[/tex]Fy = TA - 200 - (.3)Nleft - (.3)Nright = 0
    [tex]\sum[/tex]M = 5*0.3*Nleft - 5*0.3*Nright - 3*TA = 0
    What I immediately discover is that the two normal forces are equal, and therefore from the last equation TA = 0. Obviously this is not the correct answer!
    I thought that perhaps I could add a couple to the final equation to reflect the fact that the unbalanced door is trying to rotate and can't due to the door frame, but then I end up with four unknowns :-/
    What am I missing about this problem?
Draft saved Draft deleted
