Equilibrium of a Pulley System
In summary, the problem involves a system of pulleys with a hanging block and several forces acting on it. The tensions in the cables passing through the pulleys can be calculated by equating the total tensions to the weight of the block. In a single string system, each segment of the cable has the same tension.
joej24
78
The picture is located in the attachment
[tex]\sum[/tex] t = 0
[tex]\sum[/tex] Fx = 0 Although there are no horiz. forces in this problem
[tex]\sum[/tex] Fy = 0
I'm not sure how to start. On the top most pulley, I believe that there is a Tension T and a force Mg that is from the hanging block. The second pulley has a Tension pulling it up and Mg pulling it down. The last pulley has a Tension pulling it up and Mg as well as F pulling it down. First, did I analyze the forces correctly?
Or Does the entire system have a Tension pulling it up, a Force F pulling it down, and 3Mg pulling it down as well?
I'm quite confused.
  • physics.doc
If T is the tension in the upper cable, the tension in the each segment of the cable passing through the top pulley will be T/2.
Tension in the each segment of the cable passing through the middle pulley will be T/4.
Tension in the each segment of the cable passing through the bottom pulley will be ...
Total tension in the three segments of the three cables passing through the pulleys balances the weight.
Equate them and find the tension T.
So the three tensions acting on the block is T/2, T/4, T/8.
7 T/8 = Mg
T = 44.8
How did you figure out that those tensions in the cable (the one passing the middle pulley being T/4 and the one passing the bottom pulley T/8)?
In a single string, each segment has the same tension if the string is in equilibrium.
So T in the top cable is due to T/2 in each segment of the cable passing through the pulley.
Okay. Thanks
1. What is the definition of equilibrium with pulleys?
Equilibrium with pulleys refers to a state in which the forces acting on a system of pulleys are balanced, resulting in a stable and motionless system.
2. How do pulleys affect equilibrium?
Pulleys can change the direction and magnitude of forces, but they do not affect the overall equilibrium of a system. This means that the total force and torque on a system with pulleys will still be balanced.
3. What is the equation for calculating equilibrium with pulleys?
The equation for calculating equilibrium with pulleys is F1 = F2 x D2/D1, where F1 is the force applied to the first pulley, F2 is the force applied to the second pulley, and D1 and D2 are the distances from the pivot point to each pulley.
4. How can you determine the direction of the forces in a system with pulleys?
The direction of forces in a system with pulleys can be determined by looking at the direction of the string or rope attached to each pulley. The force will act in the same direction as the string or rope.
5. What factors can affect equilibrium with pulleys?
The factors that can affect equilibrium with pulleys include the number and arrangement of pulleys, the mass and distribution of weight on each pulley, and the friction or tension in the system.
