Equivalent impedance
  • Thread starter tabsquare
hello I have a problem in calculating the equivalent impedance of a simple AC circuit, where the impedances are:
Z1 = 5+i20
Z2 = 5+i20
Z3 = 10-i2,5
Z4 = -i10
Z5 = 5
and I need to find:
Z_eq = Z3 // [(Z1 // Z4) + (Z2 // Z5)]
where the + indicates 2 components in serie and the // indicates 2 components in parallel.
My calculations always bring me to
Z_eq=6,25-i3,75
but my book says Z_eq=28,33.
Which is the correct eqv impedance?
Thank you
PS-I used the formula Za//Zb = (Za*Zb)/(Za+Zb)
to calculate equivalent impedances of two components in parallel, and the sum for components in serie.
Answers and Replies
The Electrician
169
Well, there's a mistake somewhere.
If I use the values you gave for Z1 to Z5, I get the same result you did.
However, if you set Z3 = 5 + i20, then you will get the result in the book.
Ok then there probably is a mistake in the book because Z3 is in fact equal to 10-i2,5 as I calculated and as the book reports. Lost some time on this stupid mistake...
Thank you very much for taking the time to verify this! :)
Riccardo
Related Threads on Equivalent impedance
  • Last Post
11K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
